[AG-TECH] Cameras used for vic HDMI version 1.1 beta
Douglas Kosovic
douglask at itee.uq.edu.au
Fri May 29 10:25:13 CDT 2009
Hi Gurcharan,
I don't have first hand experience with anything other than the
Intensity (HDMI) and Intensity Pro (HDMI and analog component).
I'm pretty certain some additional work will be required for VIC to
properly support the Blackmagic Linux driver. I think VIC's V4L & V4L2
grabber code will drop the resolution down to 480i/480p (or 576i/576p)
for "large" capture, there may also be a need to support whatever
pixelformat the Blackmagic Linux driver uses.
Cheers,
Doug
Gurcharan S. Khanna wrote:
> Tran,
> I'm not a 100% sure about that, only about the card's inputs. Maybe
> Nathan or Doug could verify that???
> Nathan, Doug:
> Also, I understand that linux drivers are due out next month for the
> BlackMagic card.
> Will additional work be required to take advantage of that?
> Thanks,
> -gurcharan
> Tran, Quang V. wrote:
>> Gurcharan,
>> Thank you for your reply. So hdvic doesn't necessary require an HDMI
>> input? I could use either HDMI or HD-SDI i.e. the BlackMagic DeckLink
>> HD Pro or DeckLink HD Extreme?
>> Thanks,
>> Quang
>> -----Original Message-----
>> From: Gurcharan S. Khanna [mailto:gurcharan.khanna at rit.edu] Sent:
>> Friday, May 29, 2009 9:15 AM
>> To: Tran, Quang V.
>> Cc: Mike.W.Daley at cs.cardiff.ac.uk; John I. Quebedeaux, Jr;
>> ag-tech at mcs.anl.gov
>> Subject: Re: [AG-TECH] Cameras used for vic HDMI version 1.1 beta
>> Tran,
>> Note that the more expensive model of the BlackMagic card does have an
>> SDI input
>> if i'm not mistaken.
>> We have used a video scaler box to take the VGA out of a laptop and feed
>> it into the
>> BlackMagic card so the HDvic could be used to transmit the presenter's
>> desktop. that
>> worked well for up to about 20 fps or less.
>> Fyi,
>> -gurcharan
>>> I have a Sony EVIHD1 with HD-SDI out. Would the hdvic work if I use a
>>> converter like the Aja Hi5 to convert HD-SDI to HDMI and feed it to
>>> the BlackMagic Intensity Pro card? Have anyone tried this?
>>> Thanks in advance,
>>> Quang Tran
>>> LSU Health Sciences Center
>>> email: qtran3 at lsuhsc.edu
>>> tel: (504)568-2877
>>> From: ag-tech-bounces at lists.mcs.anl.gov on behalf of
>>> Sent: Thu 3/5/2009 4:37 PM
>>> To: John I. Quebedeaux, Jr
>>> Cc: ag-tech at mcs.anl.gov
>>> Hi John
>>> I'm using a SONY HDR-SR12E camera.
>>> I've tested it at 1080i and its fine.
>>> I'm also using the Intensity Pro capture card.
>>> The new vic again works fine around Cardiff but having trouble getting
>>> the feeds out to the states. Even though normal Multicast feeds get
>>> through with no problems.
>>> I cannot see Jimmy's feeds but others can (Not in UK though)
>>> We are currently trying to find out where the feed gets dropped.
>>> Mike
>>> Quoting "John I. Quebedeaux, Jr" <johnq at lsu.edu>:
>>>> So forgive me,
>>>> I've been watching these threads with interest and it hasn't been
>>> clear to
>>>> me what HDMI cameras folks might be using (if they are using them) -
>>> I do
>>>> know someone mentioned the Sony EVI-HD1, which I already have (whoot
>>> - I'm
>>>> fine there, but..)... but I'm considering trying also an HDMI camera
>> for
>>>> greater portability that I could purchase.
>>>> Could folks chime in on what cameras they're successful with on the
>> HDMI
>>>> aspect of this?
>>>> Thanks, sorry I've been quiet...
>>>> John Q.
>>>> John I. Quebedeaux, Jr.; Louisiana State University
>>>> Computer Manager LBRN; 131 Life Sciences Bldg.
>>>> e-mail: johnq at lsu.edu; web: http://lbrn.lsu.edu
>>>> phone: 225-578-0062 / fax: 225-578-2597
>>> Michael Daley M.Phil MBCS GCFA
>>> This message was sent using IMP, the Internet Messaging Program.
