[AG-TECH] AG in a virtual machine
Jon Johansson
jon.johansson at ualberta.ca
Thu May 28 15:06:55 CDT 2009
Hi Doug,
When I select the V4L2 device and then select Transmit, I get:
jonj at ubuntu:~$ vic 234.5.6.7/12000
Attached to V4L device: V4L-USB Camera (046d:08ad) /dev/video0
Attached to V4L2 device: V4L2-USB Camera (046d:08ad) /dev/video0
Segmentation fault
When I select the V4L device and then select Transmit, I get:
ioctl VIDIOCSYNC: Invalid argument
Syncerror SyncCount 1
and there is a video stream displayed (NTSC) but it's green as
shown in the attached image. Trying Pal and Secam doesn't change
this.
With a bit more care adding services to the venue client,
I can add either a VideoService, or a VideoProducerService pointing
at the V4L source, but the producer vic doesn't start - I do get
a consumer vic though, just "Waiting for video...".
Disabling and enabling the video results in a vic window appearing
briefly, just a flash of the frame, and then it disappears.
Jon.
~~ Jon I Johansson, Ph.D. * Tel.: (780) 492-9304 ~~
~~ jon.johansson at ualberta.ca * Fax.: (780) 492-1729 ~~
~~ * Office: G.S.B. 323C ~~
~~ Visualization Analyst http://sciviz.aict.ualberta.ca ~~
~~ Research Computing Group ~~
~~ Room 352, General Services Building ~~
~~ Academic Information and Communication Technologies (AICT) ~~
~~ University of Alberta ~~
~~ Edmonton, Alberta, CANADA, T6G 2H1 ~~
! "This communication is intended for the use of the recipient to !
! which it is addressed, and may contain confidential, personal, !
! and/or privileged information. Please contact us immediately !
! if you are not the intended recipient of this communication. !
! If you are not the intended recipient of this communication, !
! do not copy, distribute, or take action on it. Any !
! communication received in error, or subsequent reply, should !
! be deleted or destroyed." !
-----Original Message-----
[mailto:ag-tech-bounces at lists.mcs.anl.gov] On Behalf Of Douglas Kosovic
Sent: Tuesday, May 26, 2009 6:14 PM
To: Jon Johansson; ag-tech
Subject: Re: [AG-TECH] AG in a virtual machine
Hi Jon,
> Xawtv grabs the Logitech camera and shows video just fine, but
> vic chokes and dies with either v4l or v4l2 as a source.
What is the console output of vic? i.e. start vic on the command-line
and then click transmit in the GUI, e.g.:
vic 234.5.6.7/12000
The error output might give a hint.
Doug
Type: image/jpeg
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20090528/5be23048/attachment-0001.jpg>
