[AG-TECH] Error when connecting to accessgrid.org
Jason Bell
j.bell at cqu.edu.au
Wed Mar 25 08:33:20 CDT 2009
Jimmy
I occasionally see this error as well!
But the issue normally resolves quite quickly!
Cheers,
Jason.
From: Jimmy Miklavcic [mailto:jimmy.miklavcic at utah.edu]
Sent: Sunday, 22 March 2009 4:21 AM
To: ag-tech at mcs.anl.gov
Subject: [AG-TECH] Error when connecting to accessgrid.org
I get the following error when I connect to www.accessgrid.org
Unable to connect to database server
This either means that the username and password information in your settings.php file is incorrect or we can't contact the MySQL database server. This could mean your hosting provider's database server is down.
The MySQL error was: Lost connection to MySQL server during query.
Currently, the username is turam and the database server is db.ci.uchicago.edu.
* Are you sure you have the correct username and password?
* Are you sure that you have typed the correct hostname?
* Are you sure that the database server is running?
For more help, see the Installation and upgrading handbook. If you are unsure what these terms mean you should probably contact your hosting provider.
Jimmy Miklavcic
Multimedia Specialist
Jimmy.Miklavcic at utah.edu
UNIVERSITY OF UTAH
CTR FOR HIGH PERFORM COMPUTING
155 SOUTH 1452 EAST RM 405
SALT LAKE CITY, UT 84112-0190
Office: 801.585.9335
Fax: 801.585.5366
http://www.anotherlanguage.org
