[AG-TECH] Spam sent to room text chat
Dinale, Justin
Justin.Dinale at dsto.defence.gov.au
Thu Mar 12 17:46:18 CDT 2009
Andrew,
A few emails a go you said "I am just fiddling with the Openfire jabber source code to add the appropriate bit that will hopefully make it work with single inverted commas (to avoid needing to upgrade everyone's client).", does this mean you were able to change the AG client side to work with Openfire?
We're using AG on an intranet, and for us upgrading everyone's client is a reasonable option. If you did change the AG client side, how much work did it entail?
Cheers,
Justin
-----Original Message-----
From: ag-tech-bounces at lists.mcs.anl.gov [mailto:ag-tech-bounces at lists.mcs.anl.gov] On Behalf Of Andrew Rowley
Sent: Friday, 13 March 2009 3:46 AM
To: ag-tech at mcs.anl.gov
Subject: Re: [AG-TECH] Spam sent to room text chat
It appears that there are too many problems in the AG Toolkit Jabber client to make it work with other servers. I got it to work with openfire by changing openfire to send an id with single inverted commas instead of double ones. This lead to other issues, the main one being that it assumes that the jabber server is conference.{sub-domain}, rather than checking with the server to see what it is registered under. So jabber.mcs.anl.gov becomes conference.mcs.anl.gov without checks. Other servers don't seem to do things this way i.e. they tend to make the server conferernce.jabber.mcs.anl.gov. This is too fixed in the openfire code to change, so I have given up for now.
Andrew :)
Andrew G D Rowley
Senior Development Officer
Research Computing Services
The University of Manchester
Devonshire House, Oxford Road
Manchester, M13 9PL
t : +44 (0) 161 275 0685
e : Andrew.Rowley at manchester.ac.uk
w : www.manchester.ac.uk/researchcomputing
From: Michael Miller [mailto:mimiller at ncsa.uiuc.edu]
Sent: 12 March 2009 13:33
To: Andrew Rowley
Andrew,
I had installed OpenFire a while ago and wasn't able to get it to work with the VenueClient. Perhaps the quotes were the reason. Please let me know if you need someone to test your fix.
thanks
Michael
"If you're clear in your vision and trust the people in your team with clear objectives, they will invariably do their best to achieve everything desired, and usually deliver everything you could have hoped for and even more." -Paul Debevec
----- Original Message -----
From: "Andrew Rowley" <Andrew.Rowley at manchester.ac.uk>
To: "Natalia Costas Lago" <natalia at cesga.es>, "ag-tech" <ag-tech at mcs.anl.gov>
Sent: Thursday, March 12, 2009 6:55:43 AM GMT -06:00 US/Canada Central
Interestingly, I am looking at this at the moment. Unfortunately, the Jabber client in the toolkit has a bit of code that assumes that the XML attributes use single inverted commas. I am just fiddling with the Openfire jabber source code to add the appropriate bit that will hopefully make it work with single inverted commas (to avoid needing to upgrade everyone's client).
I will put it somewhere when I have done and let the list know.
Andrew :)
Andrew G D Rowley
Manchester, M13 9PL
From: ag-tech-bounces at lists.mcs.anl.gov [mailto:ag-tech-bounces at lists.mcs.anl.gov] On Behalf Of Natalia Costas Lago
Sent: 12 March 2009 11:44
To: ag-tech
Subject: [AG-TECH] Spam sent to room text chat
Dear all,
We received porn and ads to the text chat in our Venue Server Lobby
room. I have checked the jabber server the venue client uses is the following
"VenueServer.textHost" : 'jabber.mcs.anl.gov',
I wonder if there are some documents that explain how to deploy our own
jabber server. Or at least a way an admin can add some filters to
avoid non allowed IP addresses send messages.
Thanking you in advance.
Kind regards,
Natalia Costas Lago
Técnico de Comunicaciones - Dpto. de Comunicaciones
Centro de Supercomputacion de Galicia (CESGA)
Avenida de Vigo, s/n (Campus Sur)
15705 Santiago de Compostela - SPAIN
E-mail: natalia at cesga.es
Tel: +34 981 56 98 10 (ext. 237)
Fax: +34 981 59 46 16
Web: http://www.cesga.es/
IMPORTANT: This email remains the property of the Australian Defence Organisation and is subject to the jurisdiction of section 70 of the CRIMES ACT 1914. If you have received this email in error, you are requested to contact the sender and delete the email.
