[AG-TECH] Possible problems with the 3.2 Beta "all-in-one-installer"!
Andrew Ford
acf0659 at rit.edu
Mon Mar 9 15:45:00 CDT 2009
Jason,
At least one of the machines I was looking at had never had 3.2 installed,
so I'm pretty sure that it's the compile option issue that Tom mentioned. To
confirm I guess we'd have to check with whoever does the H264 and 3.2
Windows packaging.
Tom,
I'm sending you a lengthy email about compilation issues, since I'm not sure
how much ag-tech cares about how annoying ffmpeg is :)
--Andrew
2009/3/8 Jason Bell <j.bell at cqu.edu.au>
> Andrew
> Did you happen to install the “3.2 all-in-one-installer” first? I found I
> had to delete the “C:\Documents and Settings\[username]\Application
> Data\AccessGrid3” directory and then use 3.1 and it worked fine!
> Try using the 3.1 all in one installer and see if that helps???
> Cheers,
> Jason.
> *From:* Andrew Ford [mailto:acf0659 at rit.edu]
> *Sent:* Saturday, 7 March 2009 5:21 AM
> *To:* Jason Bell
> *Cc:* ag-tech at mcs.anl.gov; accessgrid-l at clix.aarnet.edu.au;
> AG-Tech-NZ at googlegroups.com
> *Subject:* Re: [AG-TECH] Possible problems with the 3.2 Beta
> Hi Jason,
> We've been seeing the same problems with not being able to receive h261as
> streams, except that we have AG 3.1 on all of our Windows machines. Our Macs
> can see 261as streams just fine. Has anyone else tried 261as on Windows?
> --Andrew
> 2009/3/3 Jason Bell <j.bell at cqu.edu.au>
> G'day All (Apologies for any cross posting)
> I was wondering if anyone has had any issues with the AG 3.2 Beta "all in
> one installer" lately?
> Upon recent testing, last couple of days, I have noticed 2 issues:
> · VenueVNC not working and users having to follow the instructions
> found at http://www.accessgrid.org/node/1031
> · Video* Services not displaying H261AS video Streams… When Using
> VPCScreen, sending a window using H261AS, others are able to see the video
> streams, but it is completely missing from an AG 3.2 Beta "all in one
> install". Note, if you use 3.1 "all in one install", it works fine. What
> is interesting is that it is completely missing, ie, not even a grey
> thumbnail or the likes can be seen.
> Has anyone else seen similar issues?
> Nathan, any chance of investigating these issues and repackaging the “all
> in one installer”???
> Thanks,
> Jason.
> Jason Bell, B.I.T. (Honours)
> Research Systems Support Officer
> Information Technology Division
> CQ University Australia
> Australian Research Collaboration Service
> http://www.arcs.org.au/
> E-mail : j.bell at cqu.edu.au
> jason.bell at arcs.org.au
> Work : +61 7 4930 9229
> Mobile : 0409 630897
> Postal : Building 19
> Central Queensland University
> Bruce Highway
> Rockhampton, Queensland, Australia, 4702
> Patience is a virtue.
> But if I wanted Patience,
> I would have become a Doctor.
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20090309/52318f82/attachment.htm>
