[AG-TECH] sending dv/hdv via accessgrid all in one
muhammad akl
muhammad.akl at gmail.com
Sun Jul 19 11:53:39 CDT 2009
Gurcharan
I think i've another problem with regards to AccessGrid 3.1 , the new
problem is that basic VideoConsumerService failed to start on the sender
machine and can not know why , but i've traced the venueclient log , and
noticed there that there is something wrong which i can not figure out how
to solve it , here is the debug info :
http://pastebin.com/maa3bf08
the log shows that the service was about to start automatically but for some
reasons it failed , i tried also to start it from AccessGrid node management
menu , but a pop-up message appeared containing the same error message :
> Add Servicd Failed : VidoeConsumerService
any workaround to solve this problem ?
Regards
Muhammad
On Sun, Jul 19, 2009 at 6:23 PM, muhammad akl <muhammad.akl at gmail.com>wrote:
> Gurcharan
> well, I can confirm that multicast is working as i can see the multicast
> address group in the DVTS Receiver window
> I'm streaming now again , if you're there you can check again my video
> Regards
> Muhammad
> On Sun, Jul 19, 2009 at 3:40 PM, Gurcharan S. Khanna <
> gurcharan.khanna at rit.edu> wrote:
>> muhammad,
>> 3.2-Beta! I wish I had noticed that earlier! Yes, definitely stay away
>> from that.
>> There are known problems both with DVTS (and H264) in the beta.
>> Now that you've discovered that, I have to say I have never seen the kind
>> of
>> artifacts that you show us in your DVTS image.
>> I'm connected to your sever now but I guess you must have turned off your
>> stream. I will check it again later.
>> Also, you should check trying to receive an external stream as well. If
>> you go
>> to the RIT Venue at
>> https://vv3.mcs.anl.gov:8000/Venues/8cdd226521d429b68e7e8c0158a6a663
>> there should be several DVTS streams available.
>> As John said in an earlier email, make sure multicast is working (there
>> are
>> independent ways to test that). But it looks like something in your
>> machine
>> or local network possibly.
>> -gurcharan
>> muhammad akl wrote:
>>> hi Gurcharan, John
>>> Firstly appreciated your help both , I think now the problem has taken
>>> another curve , i mean i've downgraded AccessGrid version from 3.2-Beta to
>>> AccessGrid 3.1 stable release ( also using the easyinstaller package) , and
>>> as i previously did , i've configured AccessGrid on the sender Pc to use the
>>> ExtendedVideoProducerService and again i can see my video signal fine
>>> without any problem
>>> Now at the receiver Pc , I've configured it to use the
>>> ExtendedVideoConsumerService and now it pops up the DVTS screen and I can
>>> see the stream sent by my sender pc , and did as Gurcharan said , that I
>>> clicked on each of those text lines and the DVTS window was brought up with
>>> the following problem within it :
>>> http://muhammad.akl.googlepages.com/19072009367.jpg
>>> As you can see the video is corrupted and is not clear , what can cause
>>> this problem ?
>>> my AccessGrid Server url is https://ag0.mans.edu.eg <
>>> https://ag0.mans.edu.eg/>
>>> Our Bridge Name : Mansoura University
>>> Regards
>>> Muhammad
>>> On Sun, Jul 19, 2009 at 2:08 AM, John I. Quebedeaux, Jr <johnq at lsu.edu<mailto:
>>> johnq at lsu.edu>> wrote:
>>> Muhammad, on Monday I can put up a DVTS stream into a lobby (let
>>> me know which you’re playing in, there are several these days –
>>> Louisiana has their own for example) and see what’s up.
>>> Confirm you have multicast working...
>>> It’s not clear from you on the display (receiver) machine if DVTS
>>> is starting, if you’re getting errors, etc. Is it starting but not
>>> showing anything? Can you confirm the multicast addresses
>>> involved? Are you getting “video” but it’s black for example?
>>> Thanks,
>>> John Q.
>>> -- John I. Quebedeaux, Jr.; Louisiana State University
>>> Computer Manager LBRN; 131 Life Sciences Bldg.
>>> e-mail: johnq at lsu.edu <http://johnq@lsu.edu/>; web:
>>> http://lbrn.lsu.edu <http://lbrn.lsu.edu/>
>>> phone: 225-578-0062 / fax: 225-578-2597
>>> *From: *muhammad akl <muhammad.akl at gmail.com
>>> <http://muhammad.akl@gmail.com/>>
>>> *Date: *Sat, 18 Jul 2009 19:39:16 +0300
>>> *To: *Gurcharan Khanna <gurcharan.khanna at rit.edu
>>> <http://gurcharan.khanna@rit.edu/>>
>>> *Cc: *<ag-tech at mcs.anl.gov <http://ag-tech@mcs.anl.gov/>>
>>> *Subject: *Re: [AG-TECH] sending dv/hdv via accessgrid all in one
>>> hi Gurcharan,
>>> well, the problem mainly is that i'm unable to receive my video
>>> signal at the receiver side , which actually i can see it via DVTS
>>> program at the sending side
>>> let's explain my setup in more details , i've two pcs their specs
>>> as follows :
>>> Sender PC
>>> OS : Windows XP SP3
>>> AccessGrid Ver : 3.2 Beta version ( All in one Installer made by
>>> http://www.hitlabnz.org/wiki/Access_Grid_-_Easy_Installer)
>>> Processor: Intel core 2 duo 2.3 GHZ
>>> Ram : 2 GB
>>> VGA Card : Nvidia 8400 GS ( Driver installed via nvidia website )
>>> Ethernet Type : Gigabit ethernet
>>> Firewire ports : External Pci card has two IEEE-1394 ports
>>> Input Camera : Sony DCR-TRV285E
>>> Receiver PC
>>> OS : Windows XP SP3
>>> Processor : intel pentium D 3.4 GHZ
>>> Ram : 512 MB
>>> Ethernet type : fast ethernet
>>> Now , The sender Pc is configured to Start sending Digital
>>> Video
>>> via ExtendedVideoServiceProducer Option which is found in the
>>> AccessGrid node management menu , that i've included during the
>>> installation of AccessGrid , And at this time i can see my video
>>> signal via DVTS program
>>> At the Receiver Side , I've started AccessGrid and configured It
>>> to use The ExtendedVideoConsumerService from AccessGrid node
>>> Management menu by adding a new service , and at this time i can
>>> not see anything , and no error messages appeared
>>> does my setup lacks something that's i've fogotten to do , or does
>>> i need much horse power for my PCS ?
>>> if though , what are the necessary steps to be done to be able to
>>> send and/or receive dv/hdv on windows xp ?
>>> Regards
>>> Muhammad
>>> On Sat, Jul 18, 2009 at 5:31 PM, Gurcharan S. Khanna
>>> <gurcharan.khanna at rit.edu <http://gurcharan.khanna@rit.edu/>> wrote:
>>> hi,
>>> we use it constantly. can you give us more details about your
>>> problem?
>>> e.g., specific error messages?
>>> -gurcharan
>>> muhammad akl wrote:
>>> hello,
>>> I've just installed the recent all in one accessgrid
>>> package on windows xp , the installation process went fine ,
>>> and i've added the extended video services during the
>>> installation as I want to start sedning dv/hdv video via
>>> firewire cameras ,
>>> after i've joined the lobby , i've configured the
>>> ExtendedVideoProducerService , and I can see my video fine
>>> via the DVTS program ,
>>> but the problem that i'm unable to receive it via
>>> ExtendedVideoConsumerService ,I've tried several times to
>>> enable and disable the service with no luck
>>> Anyone had a previous experience on how to get dv/hdv
>>> video on windows xp using this all in one (which includes
>>> the DVTS ) ?
>>> also anyone tried the enhanced vic that was made by
>>> vislab team (chris willing ) on windows xp and successed
>>> to integrate it with accessgrid ?
>>> Gurcharan S. Khanna, Ph.D.
>>> Director of Research Computing
>>> Office of the Vice President for Research
>>> http://rc.rit.edu <http://rc.rit.edu/> <http://rc.rit.edu/>
>>> Assistant Research Professor, Ph.D. Program
>>> Golisano College of Computing and Information Sciences
>>> http://people.rit.edu/gskpop
>>> Director, Interactive Collaboration Environments Laboratory,
>>> Center for the Advancing the Study of Cyberinfrastructure
>>> http://icelab.rit.edu <http://icelab.rit.edu/>
>>> Rochester Institute of Technology
>>> 1 Lomb Memorial Drive
>>> Rochester, New York 14623-5603
>>> Phone: 585-475-7504 ~ Cell: 585-451-8370
>>> Email: gurcharan.khanna at rit.edu <http://gurcharan.khanna@rit.edu/
>> http://rc.rit.edu
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20090719/a61271db/attachment-0001.htm>
