[AG-TECH] sending dv/hdv via accessgrid all in one
muhammad akl
muhammad.akl at gmail.com
Sun Jul 19 02:04:09 CDT 2009
hi Gurcharan, John
Firstly appreciated your help both , I think now the problem has taken
another curve , i mean i've downgraded AccessGrid version from 3.2-Beta to
AccessGrid 3.1 stable release ( also using the easyinstaller package) , and
as i previously did , i've configured AccessGrid on the sender Pc to use the
ExtendedVideoProducerService and again i can see my video signal fine
without any problem
Now at the receiver Pc , I've configured it to use the
ExtendedVideoConsumerService and now it pops up the DVTS screen and I can
see the stream sent by my sender pc , and did as Gurcharan said , that I
clicked on each of those text lines and the DVTS window was brought up with
the following problem within it :
http://muhammad.akl.googlepages.com/19072009367.jpg
As you can see the video is corrupted and is not clear , what can cause this
problem ?
my AccessGrid Server url is https://ag0.mans.edu.eg
Our Bridge Name : Mansoura University
Regards
Muhammad
On Sun, Jul 19, 2009 at 2:08 AM, John I. Quebedeaux, Jr <johnq at lsu.edu>wrote:
> Muhammad, on Monday I can put up a DVTS stream into a lobby (let me know
> which you’re playing in, there are several these days – Louisiana has their
> own for example) and see what’s up.
> Confirm you have multicast working...
> It’s not clear from you on the display (receiver) machine if DVTS is
> starting, if you’re getting errors, etc. Is it starting but not showing
> anything? Can you confirm the multicast addresses involved? Are you getting
> “video” but it’s black for example?
> Thanks,
> John Q.
> John I. Quebedeaux, Jr.; Louisiana State University
> Computer Manager LBRN; 131 Life Sciences Bldg.
> e-mail: johnq at lsu.edu; web: http://lbrn.lsu.edu
> phone: 225-578-0062 / fax: 225-578-2597
> *From: *muhammad akl <muhammad.akl at gmail.com>
> *Date: *Sat, 18 Jul 2009 19:39:16 +0300
> *To: *Gurcharan Khanna <gurcharan.khanna at rit.edu>
> *Cc: *<ag-tech at mcs.anl.gov>
> *Subject: *Re: [AG-TECH] sending dv/hdv via accessgrid all in one
> hi Gurcharan,
> well, the problem mainly is that i'm unable to receive my video signal at
> the receiver side , which actually i can see it via DVTS program at the
> sending side
> let's explain my setup in more details , i've two pcs their specs as
> follows :
> Sender PC
> OS : Windows XP SP3
> AccessGrid Ver : 3.2 Beta version ( All in one Installer made by
> http://www.hitlabnz.org/wiki/Access_Grid_-_Easy_Installer)
> Processor: Intel core 2 duo 2.3 GHZ
> Ram : 2 GB
> VGA Card : Nvidia 8400 GS ( Driver installed via nvidia website )
> Ethernet Type : Gigabit ethernet
> Firewire ports : External Pci card has two IEEE-1394 ports
> Input Camera : Sony DCR-TRV285E
> Receiver PC
> OS : Windows XP SP3
> Processor : intel pentium D 3.4 GHZ
> Ram : 512 MB
> Ethernet type : fast ethernet
> Now , The sender Pc is configured to Start sending Digital Video via
> ExtendedVideoServiceProducer Option which is found in the AccessGrid node
> management menu , that i've included during the installation of AccessGrid ,
> And at this time i can see my video signal via DVTS program
> At the Receiver Side , I've started AccessGrid and configured It to use The
> ExtendedVideoConsumerService from AccessGrid node Management menu by adding
> a new service , and at this time i can not see anything , and no error
> messages appeared
> does my setup lacks something that's i've fogotten to do , or does i need
> much horse power for my PCS ?
> if though , what are the necessary steps to be done to be able to send
> and/or receive dv/hdv on windows xp ?
> Regards
> Muhammad
> On Sat, Jul 18, 2009 at 5:31 PM, Gurcharan S. Khanna <
> gurcharan.khanna at rit.edu> wrote:
> hi,
> we use it constantly. can you give us more details about your problem?
> e.g., specific error messages?
> -gurcharan
> muhammad akl wrote:
> hello,
> I've just installed the recent all in one accessgrid package on windows xp
> , the installation process went fine ,
> and i've added the extended video services during the installation as I
> want to start sedning dv/hdv video via firewire cameras ,
> after i've joined the lobby , i've configured the
> ExtendedVideoProducerService , and I can see my video fine via the DVTS
> program ,
> but the problem that i'm unable to receive it via
> ExtendedVideoConsumerService ,I've tried several times to enable and disable
> the service with no luck
> Anyone had a previous experience on how to get dv/hdv video on windows xp
> using this all in one (which includes the DVTS ) ?
> also anyone tried the enhanced vic that was made by vislab team (chris
> willing ) on windows xp and successed to integrate it with accessgrid ?
> Gurcharan S. Khanna, Ph.D.
> Director of Research Computing
> Office of the Vice President for Research
> http://rc.rit.edu <http://rc.rit.edu/>
> Assistant Research Professor, Ph.D. Program
> Golisano College of Computing and Information Sciences
> http://people.rit.edu/gskpop
> Director, Interactive Collaboration Environments Laboratory,
> Center for the Advancing the Study of Cyberinfrastructure
> http://icelab.rit.edu <http://icelab.rit.edu/>
> Rochester Institute of Technology
> 1 Lomb Memorial Drive
> Rochester, New York 14623-5603
> Phone: 585-475-7504 ~ Cell: 585-451-8370
> Email: gurcharan.khanna at rit.edu
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20090719/551f0dea/attachment-0001.htm>
