[AG-TECH] AVCHD and AG
Gurcharan S. Khanna
gskpop at cis.rit.edu
Tue Jan 20 21:06:20 CST 2009
all,
what's the status of vic/mac/BlackMagic? is anyone working on that? i
know doug found a little
time to play with it. i'm ready to throw a student at it right now to
try to get what i want--vic with
uncompressed HD. let me know what you all think--is someone already
working on it? is it feasible?
(naturally, vic+codecs and smaller resolutions would be a by-product of
this work).
thanks,
-gurcharan
Nathan Gardiner wrote:
> Hi Doug,
> ChangHyeok Bae from Korea is here at the HIT Lab for the next 2-3 months
> working on getting the BlackMagic card working in Access Grid under
> windows.
> It would be great to have you both get in contact to discuss the
> BlackMagic card. His email address is:
> chbae at nm.gist.ac.kr
> Regards,
> Nathan Gardiner
> Human Interface Technology Lab NZ (HIT Lab NZ)
> Room 110, Old Maths Building, University of Canterbury
> DDI: +64 3 364 3072, Cell: +64 21 163 2956
> Calendar Information
> -----Original Message-----
> From: Douglas Kosovic [mailto:douglask at itee.uq.edu.au]
> Sent: Friday, 16 January 2009 2:17 p.m.
> To: Nathan Gardiner; Jimmy Miklavcic
> Cc: ag-tech at mcs.anl.gov
> Subject: RE: [AG-TECH] AVCHD and AG
> Hi Nathan
> I was adding generic support for more pixelformats in VIC's DirectShow
> grabber, with a preference for YUV420 if supported natively by the
> capture hardware.
> Setting the DirectShow SampleGrabber to YUV420 and then using
> DirectShow's "Intelligent Connect" mechanism causes the Blackmagic
> filter to get set to YUV420 720x486 (and that's 486, not 480 which is
> strange).
> So looks like adding proper Blackmagic Intensity card support requires
> explicit programmatic support of the Intensity DirectShow filter, maybe
> interrogating it and listing inputs/formats in the input menu of VIC
> (e.g. "HDMI 29.97 fps 1080i", "HDMI 25 fps 1080i", ..., "Analog YCbCr
> 480i", etc).
> If you guys are coding for the Blackmagic Intensity be my guest, it'll
> be wasted effort if we both do it.
> One of the other changes I did was add support for remote DirectShow
> filter graph connection with GraphEdit (found in Microsoft's Platform
> SDK). A screendump of GraphEdit remote filter graph connection to VIC,
> involving the Intensity Pro:
> http://www.vislab.uq.edu.au/ag3/windows/graphedit.png
> GraphEdit is very useful for seeing the properties (pixelforms,
> resolution, etc) of the filters and pins.
> Cheers,
> Doug
>> From: Nathan Gardiner [mailto:nathan.gardiner at canterbury.ac.nz]
>> Sent: Thursday, 15 January 2009 6:05 AM
>> To: Douglas Kosovic; Jimmy Miklavcic
>> Hi there,
>> We are starting to code for the HDMI Intensity card into AccessGrid
> for
>> a Windows version and should have something within the next couple of
>> months.
>> Regards,
>> Nathan Gardiner
>> From: ag-tech-bounces at lists.mcs.anl.gov
>> [mailto:ag-tech-bounces at lists.mcs.anl.gov] On Behalf Of Douglas
> Kosovic
>> Sent: Wednesday, 14 January 2009 10:46 a.m.
>> To: Jimmy Miklavcic
>> Subject: Re: [AG-TECH] AVCHD and AG
>> Hi Jimmy,
>>> Is anyone using AVCHD, HDMI and the intensity pro cards with AG on a
>>> windows XP box, or something close to this combination?
>> The Intensity Pro outputs Blackmagic HDYC (YUV 4:2:2) pixel format
> that
>> isn't supported by VIC's DirectShow grabber at the moment. It doesn't
>> matter if a AVCHD or a DV/HDV camcorder is used with the HDMI.
>> I'm currently in the process of adding multiple YUV formats support to
>> VIC's DirectShow grabber (which so far has fixed a white vertical line
>> issue with 480i DV over firewire). Maybe in the next couple of weeks
>> it'll work with the Blagmagic Intensity Pro.
>> Cheers,
>> Doug
Gurcharan S. Khanna, Ph.D.
Director of Research Computing
Office of the Vice President for Research
http://rc.rit.edu
Assistant Research Professor, Ph.D. Program
Golisano College of Computing and Information Sciences
http://people.rit.edu/gskpop
Director, Interactive Collaboration Environments Laboratory,
Center for the Advancing the Study of Cyberinfrastructure
http://icelab.rit.edu
Rochester Institute of Technology
1 Lomb Memorial Drive
Rochester, New York 14623-5603
Phone: 585-475-7504 ~ Cell: 585-451-8370
Email: gurcharan.khanna at rit.edu
