[AG-TECH] Venue Client error
George Estes
gestes at ncsa.uiuc.edu
Wed Jan 14 10:14:34 CST 2009
Hello,
I have two users with the same problem, both behind firewalls. They get this error when attempting enter a venue on our venue server. "Error entering venue (0, 'Error')" These are both AG3.1 nodes running on Windows XP that were working and now stopped working.
Here's a section of the venue client log from one. Any suggestions on what might be wrong would be appreciated.
George
12/11/08 12:48:32 10080 Toolkit config.py:609 DEBUG System hostname of EHS-Chemistry.ehs.local is valid
12/11/08 12:48:32 10080 Toolkit toolkit.py:116 DEBUG Initializing AG Toolkit version 3.1
12/11/08 12:48:32 10080 Toolkit toolkit.py:117 INFO Command and arguments: ['C:\\Program Files\\AGTk-3\\bin\\VenueClient3.py']
12/11/08 12:48:32 10080 VenueClient preferences.py:188 DEBUG Preferences.LoadPreferences: open file
12/11/08 12:48:32 10080 Toolkit toolkit.py:166 INFO Logfile Name: VenueClient.log
12/11/08 12:48:32 10080 Toolkit venueclient3.py:137 INFO wx version is: 2.6.3.3
12/11/08 12:48:32 10080 VenueClient venueclient.py:529 DEBUG __StartWebService: service manager: http://EHS-Chemistry.ehs.local:11000/ServiceManager
12/11/08 12:48:32 10080 VenueClient venueclient.py:543 DEBUG __StartWebService: node service: http://EHS-Chemistry.ehs.local:11000/NodeService
12/11/08 12:48:32 10080 NodeService agnodeservice.py:640 INFO NodeService.GetConfigurations
12/11/08 12:48:32 10080 VenueClient venueclient.py:270 DEBUG Loading node configuration: <AccessGrid.Descriptions.NodeConfigDescription instance at 0x01615A08>
12/11/08 12:48:32 10080 NodeService agnodeservice.py:379 INFO NodeService.LoadConfiguration
12/11/08 12:48:32 10080 NodeService agnodeservice.py:398 INFO Trying to load node configuration from: C:\Program Files\AGTk-3\Config\nodeConfig\default
12/11/08 12:48:32 10080 NodeService agnodeservice.py:406 DEBUG section: node
12/11/08 12:48:32 10080 NodeService agnodeservice.py:408 DEBUG servicemanagers : servicemanager0
12/11/08 12:48:32 10080 NodeService agnodeservice.py:406 DEBUG section: service1
12/11/08 12:48:32 10080 NodeService agnodeservice.py:408 DEBUG packageName : VideoService.zip
12/11/08 12:48:32 10080 NodeService agnodeservice.py:408 DEBUG resource : resource1
12/11/08 12:48:32 10080 NodeService agnodeservice.py:408 DEBUG serviceConfig : serviceconfig1
12/11/08 12:48:32 10080 NodeService agnodeservice.py:406 DEBUG section: service0
12/11/08 12:48:32 10080 NodeService agnodeservice.py:408 DEBUG packageName : AudioService.zip
12/11/08 12:48:32 10080 NodeService agnodeservice.py:408 DEBUG serviceConfig : serviceconfig0
12/11/08 12:48:32 10080 NodeService agnodeservice.py:406 DEBUG section: resource1
12/11/08 12:48:32 10080 NodeService agnodeservice.py:408 DEBUG name : Microsoft WDM Image Capture (Win32)
12/11/08 12:48:32 10080 NodeService agnodeservice.py:406 DEBUG section: servicemanager0
12/11/08 12:48:32 10080 NodeService agnodeservice.py:408 DEBUG url :
12/11/08 12:48:32 10080 NodeService agnodeservice.py:408 DEBUG builtin : 1
12/11/08 12:48:32 10080 NodeService agnodeservice.py:408 DEBUG services : service0 service1
12/11/08 12:48:32 10080 NodeService agnodeservice.py:406 DEBUG section: serviceconfig1
12/11/08 12:48:32 10080 NodeService agnodeservice.py:408 DEBUG Mute Sources : Off
12/11/08 12:48:32 10080 NodeService agnodeservice.py:408 DEBUG Thumbnail Columns : 2
12/11/08 12:48:32 10080 NodeService agnodeservice.py:408 DEBUG Frame Rate : 24
12/11/08 12:48:32 10080 NodeService agnodeservice.py:408 DEBUG Encoding : h261
12/11/08 12:48:32 10080 NodeService agnodeservice.py:408 DEBUG Start Priority : 7
12/11/08 12:48:32 10080 NodeService agnodeservice.py:408 DEBUG Transmit on Startup : On
12/11/08 12:48:32 10080 NodeService agnodeservice.py:408 DEBUG Standard : PAL
12/11/08 12:48:32 10080 NodeService agnodeservice.py:408 DEBUG Bandwidth : 800
12/11/08 12:48:32 10080 NodeService agnodeservice.py:408 DEBUG Processor usage : All
12/11/08 12:48:32 10080 NodeService agnodeservice.py:408 DEBUG Port : external-in
12/11/08 12:48:32 10080 NodeService agnodeservice.py:408 DEBUG Quality : 75
12/11/08 12:48:32 10080 NodeService agnodeservice.py:408 DEBUG Stream Name : Microsoft WDM Image Capture (Win32)
12/11/08 12:48:32 10080 NodeService agnodeservice.py:406 DEBUG section: serviceconfig0
12/11/08 12:48:32 10080 NodeService agnodeservice.py:408 DEBUG Use site id : On
12/11/08 12:48:32 10080 NodeService agnodeservice.py:408 DEBUG Silence Suppression : Off
12/11/08 12:48:32 10080 NodeService agnodeservice.py:408 DEBUG Start Priority : 5
12/11/08 12:48:32 10080 NodeService agnodeservice.py:408 DEBUG Output Gain : 50
12/11/08 12:48:32 10080 NodeService agnodeservice.py:408 DEBUG Talk : Off
12/11/08 12:48:32 10080 NodeService agnodeservice.py:408 DEBUG Input Gain : 51
12/11/08 12:48:32 10080 NodeService agnodeservice.py:483 DEBUG using builtin service manager at http://EHS-Chemistry.ehs.local:11000/ServiceManager
12/11/08 12:48:32 7628 ServiceManager agservicemanager.py:210 INFO AGServiceManager.RemoveServices
12/11/08 12:48:33 7988 ServiceManager agservicemanager.py:103 INFO AGServiceManager.AddService
12/11/08 12:48:33 7988 ServiceManager agservicemanager.py:343 INFO Installed service version: 3.9, package version: 3.9
12/11/08 12:48:33 7988 ServiceManager agservicemanager.py:378 DEBUG Executing service AudioService
12/11/08 12:48:33 7988 ServiceManager agservicemanager.py:410 INFO Running Service; options: ['C:\\Documents and Settings\\freil\\Application Data\\AccessGrid3\\local_services\\AudioService\\AudioService.py', '--port', 50301, '--serviceManagerUri', 'http://EHS-Chemistry.ehs.local:11000/ServiceManager', '--token', '0a02021421441d89b2ad92472c0f48b1']
12/11/08 12:48:33 7988 ProcessManager processmanager.py:62 DEBUG Creating process: C:\Python24\pythonw.exe "C:\Documents and Settings\freil\Application Data\AccessGrid3\local_services\AudioService\AudioService.py" --port 50301 --serviceManagerUri http://EHS-Chemistry.ehs.local:11000/ServiceManager --token 0a02021421441d89b2ad92472c0f48b1
12/11/08 12:48:33 7988 ProcessManager processmanager.py:75 DEBUG Create process returns: (<PyHANDLE:1312>, <PyHANDLE:1324>, 8396, 144)
12/11/08 12:48:33 3708 ServiceManager agservicemanager.py:234 INFO Service registered: token,url = 0a02021421441d89b2ad92472c0f48b1,http://EHS-Chemistry.ehs.local:50301/Services/AudioService.0a02021420cc1d89b2efa38f0bf762ab
12/11/08 12:48:33 7988 ServiceManager agservicemanager.py:422 INFO Service registered: http://EHS-Chemistry.ehs.local:50301/Services/AudioService.0a02021420cc1d89b2efa38f0bf762ab 0a02021421441d89b2ad92472c0f48b1
12/11/08 12:48:33 8776 ServiceManager agservicemanager.py:103 INFO AGServiceManager.AddService
12/11/08 12:48:33 8776 ServiceManager agservicemanager.py:343 INFO Installed service version: 3.7, package version: 3.7
12/11/08 12:48:33 8776 ServiceManager agservicemanager.py:378 DEBUG Executing service VideoService
12/11/08 12:48:33 8776 ServiceManager agservicemanager.py:410 INFO Running Service; options: ['C:\\Documents and Settings\\freil\\Application Data\\AccessGrid3\\local_services\\VideoService\\VideoService.py', '--port', 51694, '--serviceManagerUri', 'http://EHS-Chemistry.ehs.local:11000/ServiceManager', '--token', '0a02021421441d89b30447097b270939']
12/11/08 12:48:33 8776 ProcessManager processmanager.py:62 DEBUG Creating process: C:\Python24\pythonw.exe "C:\Documents and Settings\freil\Application Data\AccessGrid3\local_services\VideoService\VideoService.py" --port 51694 --serviceManagerUri http://EHS-Chemistry.ehs.local:11000/ServiceManager --token 0a02021421441d89b30447097b270939
12/11/08 12:48:33 8776 ProcessManager processmanager.py:75 DEBUG Create process returns: (<PyHANDLE:1180>, <PyHANDLE:1168>, 8800, 9304)
12/11/08 12:48:38 9096 ServiceManager agservicemanager.py:234 INFO Service registered: token,url = 0a02021421441d89b30447097b270939,http://EHS-Chemistry.ehs.local:51694/Services/VideoService.0a02021422601d89b4a4508ccad54d00
12/11/08 12:48:38 8776 ServiceManager agservicemanager.py:422 INFO Service registered: http://EHS-Chemistry.ehs.local:51694/Services/VideoService.0a02021422601d89b4a4508ccad54d00 0a02021421441d89b30447097b270939
12/11/08 12:48:38 10080 VenueClient venueclient.py:365 DEBUG get bridges from registry
12/11/08 12:48:38 10080 VenueClient venueclient.py:371 DEBUG Trying bridge registry: http://www.accessgrid.org/registry/peers.txt
12/11/08 12:48:38 10080 VenueClient preferences.py:188 DEBUG Preferences.LoadPreferences: open file
12/11/08 12:48:47 10080 VenueClient venueclient.py:371 DEBUG Trying bridge registry: http://www.ap-accessgrid.org/registry/peers.txt
12/11/08 12:48:47 10080 VenueClient preferences.py:188 DEBUG Preferences.LoadPreferences: open file
12/11/08 12:48:52 10080 RegistryClient registryclient.py:66 ERROR Failed to connect to registry hall.vislab.uq.edu.au:8030
Traceback (most recent call last):
File "C:\Python24\lib\site-packages\AccessGrid3\AccessGrid\Registry\RegistryClient.py", line 61, in _connectToRegistry
if self.PingRegistryPeer(tmpServerProxy) > -1:
File "C:\Python24\lib\site-packages\AccessGrid3\AccessGrid\Registry\RegistryClient.py", line 78, in PingRegistryPeer
startTime = serverProxy.Ping(time.time())
File "C:\Python24\lib\xmlrpclib.py", line 1096, in __call__
return self.__send(self.__name, args)
File "C:\Python24\lib\xmlrpclib.py", line 1383, in __request
verbose=self.__verbose
File "C:\Python24\lib\xmlrpclib.py", line 1129, in request
self.send_content(h, request_body)
File "C:\Python24\lib\xmlrpclib.py", line 1243, in send_content
connection.endheaders()
File "C:\Python24\lib\httplib.py", line 798, in endheaders
self._send_output()
File "C:\Python24\lib\httplib.py", line 679, in _send_output
self.send(msg)
File "C:\Python24\lib\httplib.py", line 646, in send
self.connect()
File "C:\Python24\lib\site-packages\AccessGrid3\AccessGrid\UrllibTransport.py", line 43, in connect
raise socket.error, msg
error: (10061, 'Connection refused')
12/11/08 12:48:52 10080 RegistryClient registryclient.py:70 INFO No bridge registry peers reachable
12/11/08 12:48:52 10080 VenueClient venueclient.py:388 ERROR LoadBridges: Can not connect to bridge registry http://www.ap-accessgrid.org/registry/peers.txt
File "C:\Python24\lib\site-packages\AccessGrid3\AccessGrid\VenueClient.py", line 375, in LoadBridges
bridgeList = self.registryClient.LookupBridge()
File "C:\Python24\lib\site-packages\AccessGrid3\AccessGrid\Registry\RegistryClient.py", line 135, in LookupBridge
bridges = self.serverProxy.LookupBridge()
AttributeError: 'NoneType' object has no attribute 'LookupBridge'
12/11/08 12:48:52 10080 VenueClient venueclient.py:397 DEBUG connect to bridge
12/11/08 12:48:52 10080 VenueClient venueclient.py:401 DEBUG exiting loadbridges
12/11/08 12:48:52 10080 VenueClientController venueclientcontroller.py:1628 DEBUG There is no personal venues file to load.
12/11/08 12:48:52 10080 NodeService agnodeservice.py:289 INFO NodeService.SetServiceEnabledByMediaType
12/11/08 12:48:52 10080 NodeService agnodeservice.py:258 INFO NodeService.GetServices
12/11/08 12:48:52 9152 ServiceManager agservicemanager.py:220 INFO AGServiceManager.GetServices
12/11/08 12:48:52 10080 NodeService agnodeservice.py:275 INFO NodeService.SetServiceEnabled
12/11/08 12:48:52 10080 NodeService agnodeservice.py:701 INFO NodeService.__SendStreamsToService
12/11/08 12:48:52 10080 NodeService agnodeservice.py:705 DEBUG service capabilities: [consumer, audio, 0a02021420cc1d89b2e1011aa51defe2, L16, 16000, 1, None, None, consumer, audio, 0a02021420cc1d89b2e1011aa51defe2, L16, 8000, 1, None, None, consumer, audio, 0a02021420cc1d89b2e1011aa51defe2, L8, 16000, 1, None, None, consumer, audio, 0a02021420cc1d89b2e1011aa51defe2, L8, 8000, 1, None, None, consumer, audio, 0a02021420cc1d89b2e1011aa51defe2, PCMU, 16000, 1, None, None, consumer, audio, 0a02021420cc1d89b2e1011aa51defe2, PCMU, 8000, 1, None, None, consumer, audio, 0a02021420cc1d89b2e1011aa51defe2, GSM, 16000, 1, None, None, consumer, audio, 0a02021420cc1d89b2e1011aa51defe2, GSM, 8000, 1, None, None, producer, audio, 0a02021420cc1d89b2e1011aa51defe2, L16, 16000, 1, None, None]
12/11/08 12:48:52 8532 ServiceManager agservicemanager.py:220 INFO AGServiceManager.GetServices
12/11/08 12:48:52 8384 ServiceManager agservicemanager.py:220 INFO AGServiceManager.GetServices
12/11/08 12:48:52 10080 NodeService agnodeservice.py:640 INFO NodeService.GetConfigurations
12/11/08 12:48:52 10080 CertificateManager certificatemanager.py:212 DEBUG Opened repository C:\Documents and Settings\freil\Application Data\AccessGrid3\Config\certRepo
12/11/08 12:48:52 10080 Toolkit toolkit.py:472 INFO Initialized certificate manager.
12/11/08 12:48:52 10080 CertificateManager certificatemanager.py:575 DEBUG Configuring standard environment
12/11/08 12:48:52 10080 CertificateManager certificatemanager.py:782 WARNING No identity certs found
12/11/08 12:48:52 10080 CertificateManager certificatemanager.py:790 WARNING No default identity certificate found
12/11/08 12:48:52 10080 CertificateManager certificatemanager.py:627 DEBUG No default identity found
12/11/08 12:48:57 10080 VenueClient preferences.py:188 DEBUG Preferences.LoadPreferences: open file
12/11/08 12:49:05 10080 VenueClient venueclientui.py:2141 INFO Entering venue at https://msp-ag.ncsa.uiuc.edu:8000/Venues/default
12/11/08 12:49:05 10080 VenueClientController venueclientcontroller.py:457 DEBUG VenueClientController calling Venue.EnterVenue
12/11/08 12:49:05 10080 VenueClient venueclient.py:1283 DEBUG EnterVenue; url=https://msp-ag.ncsa.uiuc.edu:8000/Venues/default type=<type 'str'>
12/11/08 12:49:05 10080 NodeService agnodeservice.py:663 INFO NodeService.GetCapabilities
12/11/08 12:49:05 10080 NodeService agnodeservice.py:258 INFO NodeService.GetServices
12/11/08 12:49:05 4988 ServiceManager agservicemanager.py:220 INFO AGServiceManager.GetServices
12/11/08 12:49:05 10080 VenueClient venueclient.py:1295 DEBUG Capability on VenueEnter: consumer, audio, 0a02021420cc1d89b2e1011aa51defe2, L16, 16000, 1, None, None
12/11/08 12:49:05 10080 VenueClient venueclient.py:1295 DEBUG Capability on VenueEnter: consumer, audio, 0a02021420cc1d89b2e1011aa51defe2, L16, 8000, 1, None, None
12/11/08 12:49:05 10080 VenueClient venueclient.py:1295 DEBUG Capability on VenueEnter: consumer, audio, 0a02021420cc1d89b2e1011aa51defe2, L8, 16000, 1, None, None
12/11/08 12:49:05 10080 VenueClient venueclient.py:1295 DEBUG Capability on VenueEnter: consumer, audio, 0a02021420cc1d89b2e1011aa51defe2, L8, 8000, 1, None, None
12/11/08 12:49:05 10080 VenueClient venueclient.py:1295 DEBUG Capability on VenueEnter: consumer, audio, 0a02021420cc1d89b2e1011aa51defe2, PCMU, 16000, 1, None, None
12/11/08 12:49:05 10080 VenueClient venueclient.py:1295 DEBUG Capability on VenueEnter: consumer, audio, 0a02021420cc1d89b2e1011aa51defe2, PCMU, 8000, 1, None, None
12/11/08 12:49:05 10080 VenueClient venueclient.py:1295 DEBUG Capability on VenueEnter: consumer, audio, 0a02021420cc1d89b2e1011aa51defe2, GSM, 16000, 1, None, None
12/11/08 12:49:05 10080 VenueClient venueclient.py:1295 DEBUG Capability on VenueEnter: consumer, audio, 0a02021420cc1d89b2e1011aa51defe2, GSM, 8000, 1, None, None
12/11/08 12:49:05 10080 VenueClient venueclient.py:1295 DEBUG Capability on VenueEnter: producer, audio, 0a02021420cc1d89b2e1011aa51defe2, L16, 16000, 1, None, None
12/11/08 12:49:05 10080 VenueClient venueclient.py:1295 DEBUG Capability on VenueEnter: consumer, video, 0a02021422601d89b33101c04559eb5b, H261, 90000, 1, None, None
12/11/08 12:49:05 10080 VenueClient venueclient.py:1295 DEBUG Capability on VenueEnter: producer, video, 0a02021422601d89b33101c04559eb5b, H261, 90000, 1, None, None
12/11/08 12:49:05 10080 VenueClient venueclient.py:1295 DEBUG Capability on VenueEnter: producer, Beacon, 1, ANY, 0, 1, None, None
12/11/08 12:49:05 10080 VenueClient venueclient.py:1295 DEBUG Capability on VenueEnter: consumer, Beacon, 1, ANY, 0, 1, None, None
12/11/08 12:49:05 10080 VenueClient venueclient.py:1320 DEBUG calling __EnterVenue
12/11/08 12:49:05 10080 VenueClient venueclient.py:1021 DEBUG EnterVenue: Invoke Venue.Enter
12/11/08 12:49:06 10080 VenueClient venueclient.py:1023 DEBUG after Venue.Enter
12/11/08 12:49:06 10080 VenueClient venueclient.py:1025 DEBUG EnterVenue: Invoke Venue.getstate
12/11/08 12:49:06 10080 VenueClient venueclient.py:1345 ERROR EnterVenue: failed
File "C:\Python24\lib\site-packages\AccessGrid3\AccessGrid\VenueClient.py", line 1321, in EnterVenue
self.__EnterVenue(URL,withcert)
File "C:\Python24\lib\site-packages\AccessGrid3\AccessGrid\VenueClient.py", line 1026, in __EnterVenue
state = self.__venueProxy.GetState()
File "C:\Python24\lib\site-packages\AccessGrid3\AccessGrid\interfaces\Venue_client.py", line 101, in GetState
self.binding.Send(None, None, request, soapaction="urn:#GetState", **kw)
File "C:\Python24\lib\site-packages\ZSI\client.py", line 266, in Send
self.h.connect()
File "C:\Python24\lib\site-packages\M2Crypto\httpslib.py", line 50, in connect
self.sock.connect((self.host, self.port))
File "C:\Python24\lib\site-packages\M2Crypto\SSL\Connection.py", line 169, in connect
ret = self.connect_ssl()
File "C:\Python24\lib\site-packages\M2Crypto\SSL\Connection.py", line 162, in connect_ssl
return m2.ssl_connect(self.ssl)
SSLError: (0, 'Error')
12/11/08 12:49:06 10080 VenueClient venueclientui.py:3182 DEBUG bin.VenueClient::EnterVenue: Enter venue with url: https://msp-ag.ncsa.uiuc.edu:8000/Venues/default
12/11/08 12:49:06 10080 VenueClient venueclientui.py:3198 DEBUG warningString: (0, 'Error')
12/11/08 12:49:06 10080 VenueClientController venueclientcontroller.py:459 DEBUG VenueClientController after Venue.EnterVenue
12/11/08 12:49:09 10080 VenueClient venueclientui.py:2141 INFO Entering venue at https://msp-ag.ncsa.uiuc.edu:8000/Venues/default
12/11/08 12:49:09 10080 VenueClientController venueclientcontroller.py:457 DEBUG VenueClientController calling Venue.EnterVenue
12/11/08 12:49:09 10080 VenueClient venueclient.py:1283 DEBUG EnterVenue; url=https://msp-ag.ncsa.uiuc.edu:8000/Venues/default type=<type 'str'>
12/11/08 12:49:09 10080 NodeService agnodeservice.py:663 INFO NodeService.GetCapabilities
12/11/08 12:49:09 10080 NodeService agnodeservice.py:258 INFO NodeService.GetServices
12/11/08 12:49:09 9044 ServiceManager agservicemanager.py:220 INFO AGServiceManager.GetServices
12/11/08 12:49:09 10080 VenueClient venueclient.py:1295 DEBUG Capability on VenueEnter: consumer, audio, 0a02021420cc1d89b2e1011aa51defe2, L16, 16000, 1, None, None
12/11/08 12:49:09 10080 VenueClient venueclient.py:1295 DEBUG Capability on VenueEnter: consumer, audio, 0a02021420cc1d89b2e1011aa51defe2, L16, 8000, 1, None, None
12/11/08 12:49:09 10080 VenueClient venueclient.py:1295 DEBUG Capability on VenueEnter: consumer, audio, 0a02021420cc1d89b2e1011aa51defe2, L8, 16000, 1, None, None
12/11/08 12:49:09 10080 VenueClient venueclient.py:1295 DEBUG Capability on VenueEnter: consumer, audio, 0a02021420cc1d89b2e1011aa51defe2, L8, 8000, 1, None, None
12/11/08 12:49:09 10080 VenueClient venueclient.py:1295 DEBUG Capability on VenueEnter: consumer, audio, 0a02021420cc1d89b2e1011aa51defe2, PCMU, 16000, 1, None, None
12/11/08 12:49:09 10080 VenueClient venueclient.py:1295 DEBUG Capability on VenueEnter: consumer, audio, 0a02021420cc1d89b2e1011aa51defe2, PCMU, 8000, 1, None, None
12/11/08 12:49:09 10080 VenueClient venueclient.py:1295 DEBUG Capability on VenueEnter: consumer, audio, 0a02021420cc1d89b2e1011aa51defe2, GSM, 16000, 1, None, None
12/11/08 12:49:09 10080 VenueClient venueclient.py:1295 DEBUG Capability on VenueEnter: consumer, audio, 0a02021420cc1d89b2e1011aa51defe2, GSM, 8000, 1, None, None
12/11/08 12:49:09 10080 VenueClient venueclient.py:1295 DEBUG Capability on VenueEnter: producer, audio, 0a02021420cc1d89b2e1011aa51defe2, L16, 16000, 1, None, None
12/11/08 12:49:09 10080 VenueClient venueclient.py:1295 DEBUG Capability on VenueEnter: consumer, video, 0a02021422601d89b33101c04559eb5b, H261, 90000, 1, None, None
12/11/08 12:49:09 10080 VenueClient venueclient.py:1295 DEBUG Capability on VenueEnter: producer, video,
