[AG-TECH] webcam problem - lenovo T500 (Fedora Core 10)
Robert Ackland
robert.ackland at anu.edu.au
Mon Feb 16 23:24:15 CST 2009
Hi Doug,
This solution worked without a hitch for me (BTW - I did build for
32-bit). Now enjoying using AG on my Lenovo T500 running FC10.
Thanks a lot!
Rob
Douglas Kosovic wrote:
> Just a quick follow up, some users reported an issue with the video
> appearing as green and purple from the capture device, so I've made
> available a new version with a bug fix.
> x86_64 Fedora 10 RPM:
> http://www.vislab.uq.edu.au/ag3/fedora/development/RPMS/vic-2.8ucl1.4.0-0.1.20090213svn.fc10.x86_64.rpm
> the corresponding src RPM :
> http://www.vislab.uq.edu.au/ag3/fedora/development/SRPMS/vic-2.8ucl1.4.0-0.1.20090213svn.fc10.src.rpm
> Doug
>> Anyway, I've got a new version of VIC that will pad the video frame
>> with a black border if it doesn't support 352x288 or 176x144. If you
>> are running x86_64 Fedora 10, the RPM can be obtained from:
>> http://www.vislab.uq.edu.au/ag3/fedora/development/RPMS/vic-2.8ucl1.4.0-0.1.20090212svn.fc10.x86_64.rpm
>> and installed by issuing (as root user) :
>> rpm -Uvh vic-2.8ucl1.4.0-0.1.20090212svn.fc10.x86_64.rpm
>> I don't have any i386 RPM handy, but it can be built by downloading:
>> http://www.vislab.uq.edu.au/ag3/fedora/development/SRPMS/vic-2.8ucl1.4.0-0.1.20090212svn.fc10.src.rpm
>> then issue the following:
>> rpmbuild --rebuild vic-2.8ucl1.4.0-0.1.20090212svn.fc10.src.rpm
>> install any missing build dependencies with a yum install.
>> This new version of vic also supports libvl4, see:
>> http://fedoraproject.org/wiki/Features/BetterWebcamSupport
>> which was introduced in Fedora 10 for better webcam support.
>> The new vic RPM will be making it's way into the AG3 RPM repository
>> soon, probably next week.
>> Cheers,
>> Doug
