[AG-TECH] Recording and streaming access grid session using Windows Media Encoder or VLC
Todd Zimmerman
todd.zimmerman at ubc.ca
Tue Feb 3 13:26:51 CST 2009
On Mon, 2009-02-02 at 15:46 -0600, Tran, Quang V. wrote:
> Is it possible to use Windows Media Encoder or VLC to capture and
> stream an access grid session? If not, is there another way to do
> this?
Are you looking to webstream it to browser/clients? Or record /
rebroadcast via AG?
As Jeremy mentioned, agvcr will record and rebroadcast the AG event, but
will still only be available for AG style clients.
Webstreaming is a bit more difficult since AG is made up of multiple
video feeds etc. If there is a specific 'presenting' site, then we use
a separate capture box (with a split of the primary camera feed and a
separate 'mixed' audio feed from all the sits) - then used VLC to send
it to a Quicktime/Darwin streaming server. VLC will also concurrently
record the single video/mixed(all sites) audio for a webstream archive.
Cheers,
Todd
