[AG-TECH] Multiple X Screens and VNC Problem (Linux)
Christoph Willing
c.willing at uq.edu.au
Tue Feb 3 00:40:08 CST 2009
Jason,
I just had a quick look at this on machines with the same hardware as
you and running vino as the rdesktop server. Using tightvnc as the
viewer, I see the same problem - only the primary output (2 screens
Twinviewed) is seen at the viewer.
However if I run vinagre as the viewer I can see all 4 screens. The
only problem is that the cursor disappears and I therefore have no
control of the remote desktop - so some advance but ...
This test was with Slackware 12.2 & gnome 2.24. Since vino & vinagre
are part of gnome, it may be that different versions of it will behave
differently (better?) as the versions increase.
chris
On 03/02/2009, at 10:23 AM, Jason Bell wrote:
> G’day All
> As an update, I have also tried x11vnc using a variety of settings (-
> xinerama -noxwarppointer -noshm -noxdamage –noxfixes to name a few)
> without any luck.
> I have tried recompiling, re-installing and re-starting vino, as
> suggest http://bugzilla.gnome.org/show_bug.cgi?id=346258
> I have also tried and number of xorg.conf settings.
> The interesting kicker is that similar problems occur when using
> synergy… IE, can only control one of the screens.
> I am now tending to think that the issue is more of an nvidia driver
> issue or an xorg issue.
> I initially submitted a bug report to the gnome forums, see http://bugzilla.gnome.org/show_bug.cgi?id=570178
> , but with suspecting the nvidia driver, I have submitted a nvidia
> forum post, see http://www.nvnews.net/vbulletin/showthread.php?t=127386
> Thanks for everyone’s comments so far and I will keep you all posted.
> Regards,
> Jason.
> _____________________________________________
> From: Jason Bell
> Sent: Saturday, 31 January 2009 11:09 AM
> To: ag-tech at mcs.anl.gov
> Subject: Multiple X Screens and VNC Problem (Linux)
> G’day All
> I was hoping that someone might be able to help me out with a problem.
> I have a Access Grid machine (details to follow) that has 2 x dual
> head video cards. I recently upgraded the machine to fedora 10 (No
> distro flame wars please) in which I can no longer remote desktop
> (using vnc) properly to be able to see and control all X Screens (4
> in total).
> In previous versions of Linux, I use to use "Desktop Sharing" in
> KDE, but Krfb recently due to some software updates, has been found
> to be problematic.
> I am currently trying to use "Remote Desktop (Gnome)" in which
> appears to work fine, but only allows me to control the primary
> display screen. I have also tried x0vncserver with similar results.
> I am using 2 nVidia Quadro FX1700 video cards, using nvidia-setting
> to configure the 4 displays using xinerama. Note: if I use Separate
> Screens, I can only control the first screen, if I use Twinview, I
> am able to control the first 2 screens, but not the other 2.
> Also note that I need to be able to connect to this "desktop" via a
> windows machine, using something like realvnc or ultravnc (I have
> tried both).
> Therefore, I was wondering if anyone knew a solution to this problem
> as google doesn't seem to be helping me this time round. Though it
> does appear to be less an "distro" problem, as I have seen people
> (on the web) complaining about similar problems with other flavours
> of Linux.
> Someone mentioned that there might be a -ignorexinerama option
> within the server or vncviewer, but I haven't been able to find
> anything.
> Details on the system are as follows:
> Dell Precision T3400
> 2.4GHz quad-core Core 2 (Q6600)
> Dual 512MB PCIe x16 nVidia Quadro FX1700 video cards
> 2GB of Memory
> 320GB SATA HDD (3.0Gb/s, 7.2k RPM)
> Gigabit NIC
> 16X max DVD+/-RW Drive
> Running Fedora 10 (x86_64 Version)
> Your assistance in helping me to solve this problem would be
> extremely appreciated.
> Regards,
> Jason.
> Jason Bell, B.I.T. (Honours)
> Research Systems Support Officer
> Information Technology Division
> CQ University Australia
> Australian Research Collaboration Service
> http://www.arcs.org.au/
> E-mail : j.bell at cqu.edu.au
> jason.bell at arcs.org.au
> Work : +61 7 4930 9229
> Mobile : 0409 630897
> Postal : Building 19
> Central Queensland University
> Bruce Highway
> Rockhampton, Queensland, Australia, 4702
> Patience is a virtue.
> But if I wanted Patience,
> I would have become a Doctor.
Christoph Willing +61 7 3365 8316
QCIF Access Grid Manager
University of Queensland
