[AG-TECH] AG venue client crashes on Win 7
Nagykaldi, Zsolt F. (HSC)
Zsolt-Nagykaldi at ouhsc.edu
Thu Dec 10 14:00:49 CST 2009
The OS is Win 7, but I run the app under the Win XP compatibility option (in Win 7) as suggested on this forum before. I could not even run it natively on Win 7.
Zsolt Nagykaldi, PhD
Assistant Professor of Research
Clinical IT Specialist
University of Oklahoma Health Sciences Center
Department of Family & Preventive Medicine
900 N.E. 10th Street
Oklahoma City, OK 73104
Phone: (405) 271-8000 ext.1-32208
Fax: (405) 271-2784
From: ag-tech-bounces at lists.mcs.anl.gov [ag-tech-bounces at lists.mcs.anl.gov] On Behalf Of Thomas Uram [turam at mcs.anl.gov]
Sent: Thursday, December 10, 2009 1:34 PM
To: Nagykaldi, Zsolt F. (HSC)
Cc: ag-tech at lists.mcs.anl.gov
Subject: Re: [AG-TECH] AG venue client crashes on Win 7
Hi Zsolt:
Can you clarify which os you are using? The subject says win7, but the mail says winxp.
Tom
On Dec 10, 2009, at 12:09 PM, "Nagykaldi, Zsolt F. (HSC)" <Zsolt-Nagykaldi at ouhsc.edu<mailto:Zsolt-Nagykaldi at ouhsc.edu>> wrote:
I can start and use rat from the command line just fine.
When I start vic from the command line I get an error message: "TkFontPkgFree: all fonts should have been freed already"
Fax: (405) 271-2784
From: ag-tech-bounces at lists.mcs.anl.gov<mailto:ag-tech-bounces at lists.mcs.anl.gov> [ag-tech-bounces at lists.mcs.anl.gov] On Behalf Of Nagykaldi, Zsolt F. (HSC)
Sent: Thursday, December 10, 2009 11:32 AM
To: <mailto:ag-tech at lists.mcs.anl.gov> ag-tech at lists.mcs.anl.gov<mailto:ag-tech at lists.mcs.anl.gov>
Subject: [AG-TECH] AG venue client crashes on Win 7
Has any of you seen this behavior? Solutions?
When the AG venue client (v3.2) enters a venue on a Win 7 machine, it hangs when it tries to pull up vic and rat and then crashes: "pythonw.exe has stopped working - prob event name: appcrash". I am running the client under Win XP SP3 compatibility and already added C:\Python24 to the path.
Thanks!
Zsolt
Fax: (405) 271-2784
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20091210/4670e831/attachment.htm>
