[AG-TECH] Status of AG Connector plugin?
Mike.W.Daley at cs.cardiff.ac.uk
Mon Dec 7 02:48:23 CST 2009
Many Thanks
I did not spot the spelling mistake.
Mike
Quoting Namgon Kim <ngkim at netmedia.gist.ac.kr>:
> Dear Mike,
> I misspelled that line. It should be 'executable', not 'exectable'.
> I fixed the problem. You can download the fixed version from the
> AGConnector web page.
> Thank you.
> Namgon
> 2009/12/6 <Mike.W.Daley at cs.cardiff.ac.uk>
> Hi Namgon
> Been doing a bit of hacking around.
> If you run VenueClient3 from the command line you see the following error.
> Traceback (most recent call last):
> File "C:\Program Files\AGTk-3\bin\VenueClient3.py", line 173, in ?
> main()
> File "C:\Program Files\AGTk-3\bin\VenueClient3.py", line 147, in main
> vcc = VenueClientController()
> File
> "C:\Python24\lib\site-packages\AccessGrid3\AccessGrid\VenueClientControll
> er.py", line 66, in __init__
> self.agent = UMTPAgent(self, log)
> File
> "C:\Python24\lib\site-packages\AccessGrid3\AccessGrid\UMTP.py", line
> 34,
> in __init__
> self.apm = AgentProcessManager(self.log)
> File
> 372,
> in __init__
> self.SetExecutable(".", executable)
> File
> 378,
> in SetExecutable
> if not os.path.exists(self.exectable):
> AttributeError: AgentProcessManager instance has no attribute 'exectable'
> If you load UMTP.py and comment out line 378 and 379 The Client will
> launch successfully with no error. This is running under Windows 7
> by the way.
> Cannot check it further at the moment as there are no servers around.
> Will try and set one up next week back at the University.
> Mike
> Quoting Jeremy Mann <jeremymann at gmail.com>:
> On Fri, Dec 4, 2009 at 11:12 AM, Thomas Uram <turam at mcs.anl.gov> wrote:
> I expect you'll find some info about the error in the VenueClient.log file,
> in the Access Grid directory.
> Linux: ~/.AccessGrid3/Logs
> Windows: documents and settings\username\application data\accessgrid3\logs
> This is where it "hangs" in the VenueClient log:
> VenueClientController VenueClientController.py:1646 DEBUG THere is no
> personal venues file to load.
> Jeremy Mann
> jeremy at biochem.uthscsa.edu
> University of Texas Health Science Center
> Bioinformatics Core Facility
> http://www.bioinformatics.uthscsa.edu
> Phone: (210) 567-2672
> Michael Daley M.Phil MBCS GCFA
> This message was sent using IMP, the Internet Messaging Program.
