[AG-TECH] VPC Screen h261AS converting.
Jason Bell
j.bell at cqu.edu.au
Tue Dec 1 20:05:36 CST 2009
ZsoltNagykaldi
I know there are issues with the Windows install of AG 3.2 Beta.
See http://www.accessgrid.org/node/1854 for some information.
Unfortunately the issues I have seen are slightly different to the problem you are having.
Try renaming the directory C:\Documents and Settings\[username]\Application Data\AccessGrid3 and starting the software again, you will have to setup things again, but it will remove any possible issues from AG 3.2.
I hope this helps.
Cheers,
Jason.
-----Original Message-----
From: ag-tech-bounces at lists.mcs.anl.gov [mailto:ag-tech-bounces at lists.mcs.anl.gov] On Behalf Of Nagykaldi, Zsolt F. (HSC)
Sent: Thursday, 5 November 2009 11:24 PM
To: ag-tech at mcs.anl.gov
Subject: Re: [AG-TECH] VPC Screen h261AS converting.
I wonder if any of you have seen this issue:
Win XP SP2, standard setup, firewall, antivirus off. AG Toolkit 3.2 properly installed. When the venue client starts the process phytonw is killed in 3 seconds after it is fired up, killing the client as well. When I down-grade to v3.1 (beta 1 or 2), the client is not killed any more, but it gets stuck at the "loading node configuration" step and never proceeds. I haven't seen this before and I would appreciate your insights. I tried everything I could think of.
Thanks!
ZsoltNagykaldi, PhD
Assistant Professor of Research
Clinical IT Specialist
University of Oklahoma Health Sciences Center
Department of Family & Preventive Medicine
900 N.E. 10th Street
Oklahoma City, OK 73104
Phone: (405) 271-8000 ext.1-32208
Fax: (405) 271-2784
