[AG-TECH] RAT KDE4 Issues
Zimmerman, Todd
todd.zimmerman at ubc.ca
Thu Sep 25 12:29:44 CDT 2008
Hi All,
Just wondering if anyone has RAT working under KDE4. It seemed to be
working under Gnome (Fedora9) but since switching to KDE4 I get
nothing.
When starting from the command line, I get a series of the following
in /var/log/messages:
Sep 25 10:25:23 kernel: 5:1:1: usb_set_interface failed
No GUI shows up (firewall is off, selinux is permissive), until finally
I get the following output on the command line:
RAT v4.4.01: Failed to rendezvous with UI - Likely firewall/VPN issue
RAT v4.4.01: UI failed mbus.go rendezvous with controller
All rat processes die except the rat-4.4.01-media process which requires
a kill.
If I leave rat media on long enough I get:
ALSA lib pcm_direct.c:975:(snd1_pcm_direct_initialize_slave) unable to
install hw params
ALSA lib pcm_dmix.c:1020:(snd_pcm_dmix_open) unable to initialize slave
Any thoughts? (other than switch to gnome ;-))
Collaboration & Visualization Specialist
UBC Okanagan - web.ubc.ca
WestGrid - www.westgrid.ca
Ph. 250-807-9979
Todd Zimmerman - todd.zimmerman at ubc.ca
