[AG-TECH] Osprey 440 capture card sync problem.
Lloyd Pearson
lloyd.pearson at otago.ac.nz
Mon Sep 22 00:36:43 CDT 2008
Hello everyone,
We have run some Osprey 440 capture cards on Dell Precision 490 boxes running Access Grid 3.1 without significant problems for several months. However after a clean install of Windows XP on one machine, the AG H261 video appeared as almost horizontal lines, sloping upwards to the right. It seemed to be a horizontal sync problem. Later the same day, on another similar Dell machine that had run for about 2 months, the same H261 problem happened without any outside help that I know of. Maybe coincidence! (Neither machines were getting daily updates that I was aware of.)
The cameras (1 a Canon HV20, the other a VideoLabs) worked normally on both machines using Osprey's SwiftCap, Microsoft Moviemaker and ConferenceXP.
They also worked normally using H264 -Mpeg4 on Access Grid.
However, AG H261 was normal if the camera was fed into a composite-USB adapter from Belkin.
The Viewcast Osprey 440 driver in use had been the latest: ver. 4.0.4.36 from late 2007. This has been uninstalled, reinstalled and the second PC rebuilt to XP SP3 with no updates before installing the Osprey driver. Changing capture settings has made no difference.
Any ideas?
Lloyd Pearson
AVCC Operator
University of Otago
Ph +64 3 479 8997
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20080922/19492cd6/attachment.htm>
