[AG-TECH] VenueClient crashes
muhammad akl
muhammad.akl at gmail.com
Wed Oct 22 10:05:37 CDT 2008
Christoph,
Now everything seems to work fine with Nvidia chip card and it's driver on
ubuntu hardy , also upgraded my connection to 1Gbps. but the problem now is
that other participants are not able to see my video while i could see their
vidoes (they are using normal video streaming not DV or HDV) , So I would
like to ask
Must be other participants in the node have the same hardware , I mean must
they have nvidia cards , 1Gbps connection, and aghdvic application installed
or i can summarize that the question : what are the requirements should be
existed to transmit DV or HDV between mustlicast group in the same node ?
I hope your answer contains the required hardwares and softwares as well .
Regards
Muhammad
On Sun, Oct 19, 2008 at 9:53 PM, Christoph Willing <c.willing at uq.edu.au>wrote:
> On 19/10/2008, at 11:14 PM, muhammad akl wrote:
>> Hi Christoph ,
>> Thanks alot for your relpy , about the root login I was just testing AG on
>> personal computer not in a production environment , but sure you are
>> completely right .
>> the second problem now I'm facing is caputring video from my digital
>> camera , now I'm using debian lenny instead of ubuntu and all things are
>> fine and could get the video from my sony camera but the picture is
>> exteremely strange here is a screenshot :
>> http://muhammad.akl.googlepages.com/acessgrid.jpg
> Muhammad,
> That looks like you don't have an nVidia graphics card, or it is an nVidia
> card running with the "nv" driver rather than the "nvidia" driver.
> Like most other distros, lenny ships with the nv driver as the default for
> nVidia cards. However the advanced features in the nvidia driver are needed.
> I haven't looked recently but I don't think there is a package for lenny yet
> which supplies the binary nvidia driver module. This means you'll have to
> download the driver from the Nvidia web site (
> http://www.nvidia.com/object/unix.html) and install it manually yourself.
> FYI, Ubuntu has the nvidia-glx package available which supplies the binary
> nvidia driver.
> And for the SimpleHDvidoeservice , it didn't work for me the service that
>> worked here DVideoservice
> This is probably because the SimpleHDVideoService defaults to HDV when your
> camera is set to DV format. In this case, you need to set the service to DV
> format in the service's configuration panel (then disable and re-enable the
> service). Don't forget to store the configuration too.
> my camera model is :
>> Sony DCR-TRV285E
>> p.s : will the new kernel stack that supports firewire be better the
>> current one ?
> I believe other distros trying the new stack have had some problems so far.
> chris
> Christoph Willing +617 3365 8350
> QCIF Access Grid Manager
> University of Queensland
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20081022/86c25121/attachment.htm>
