[AG-TECH] VenueClient crashes
muhammad akl
muhammad.akl at gmail.com
Sun Oct 19 01:51:09 CDT 2008
hey all,
I'm just using AccessGrid some days ago , using ubuntu 8.04 hardy . I
followed the instruction at Vislab site and got everything successfully
installed.
The first time i started VenueClient , everything worked fine without any
problem , but when i tried to configure it to use my digital camera (another
problem will talk abt it later ) i had no luck to see the camera when chose
DVidoservice then i closed the application and when tried to start it again,
it suddenly disappear . I used VenueClient (Debug) and got these errors :
/usr/bin/VenueClient3.py -d
> 10/19/2008 08:41:20 AM -1210144576 Toolkit Toolkit.py:166 INFO Logfile
> 10/19/2008 08:41:20 AM -1210144576 Toolkit Config.py:674 DEBUG System
> hostname of accessgrid.mans.edu.eg is valid
> 10/19/2008 08:41:20 AM -1210144576 Toolkit Toolkit.py:116 DEBUG
> Initializing AG Toolkit version 3.2 beta
> 10/19/2008 08:41:20 AM -1210144576 Toolkit Toolkit.py:117 INFO Command
> and arguments: ['/usr/bin/VenueClient3.py', '-d']
> 10/19/2008 08:41:20 AM -1210144576 Platform Config.py:917 INFO gnome
> directory /root/.gnome/application-info or /root/.gnome/mime-info not found,
> not registering file type .agpkg3 with gnome
> not registering file type .vv3d with gnome
> 10/19/2008 08:41:20 AM -1210144576 VenueClient Preferences.py:206 DEBUG
> Preferences.LoadPreferences: open file
> 10/19/2008 08:41:20 AM -1210144576 Toolkit VenueClient3.py:127 INFO wx
> version is: 2.8.7.1
> 10/19/2008 08:41:20 AM -1210144576 VenueCache VenueCache.py:43 DEBUG
> Loading venue cache from /root/.AccessGrid3/Caches/venues
> 10/19/2008 08:41:20 AM -1210144576 VenueClient VenueClient.py:541 DEBUG
> __StartWebService: service manager:
> http://192.168.200.67:11000/ServiceManager
> 10/19/2008 08:41:20 AM -1210144576 VenueClient VenueClient.py:555 DEBUG
> __StartWebService: node service: http://192.168.200.67:11000/NodeService
> 10/19/2008 08:41:20 AM -1210144576 Toolkit VenueClient3.py:233 ERROR
> Error in VenueClient main
> Traceback (most recent call last):
> File "/usr/bin/VenueClient3.py", line 136, in main
> nodeConfigName=nodeConfig)
> File
> "/var/lib/python-support/python2.5/AccessGrid3/AccessGrid/VenueClient.py",
> line 266, in __init__
> if int(self.preferences.GetPreference(Preferences.MULTICAST)):
> ValueError: invalid literal for int() with base 10: 'False'
this problem happens every time i start the application
Regards
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20081019/8411f163/attachment.htm>
