[AG-TECH] No Services in new AG3.1 install
Thomas D. Uram
turam at mcs.anl.gov
Thu Oct 9 11:27:05 CDT 2008
Bonjour does not figure in this problem.
In AG3.1, the services launch and then register with the service
manager. This is failing for your user. Common reasons for this
failure are related to the hostname not resolving properly (unlikely in
this case, unless the IP address being used is somehow incorrect) and
firewall configuration. I'd check the latter. I'm curious to know how
this turns out.
fyi, in AG 3.2, the core services are run inside the VenueClient
process, so no network communication occurs between the components, and
this problem would not occur.
Tom
On 10/9/08 11:13 AM, George Estes wrote:
> Does it make a difference? I thought Bonjour was optional?
> From: "Tom Coffin" <tcoffin at ncsa.uiuc.edu>
> To: "George Estes" <gestes at ncsa.uiuc.edu>
> Sent: Thursday, October 9, 2008 10:46:30 AM GMT -06:00 US/Canada Central
> Subject: Re: [AG-TECH] No Services in new AG3.1 install
> did they install Bonjour?
> George Estes wrote:
>> Hello,
>> I have a new AG user at a local high school installing AG3.1. When he runs the Venue Client on a Windows XP machine the client doen't load the default services, AudioService and VideoConsumerService and when he tries to add a Service he get an error. The school is behind a firewall and uses a proxy server. Any thoughts on what the problem might be would be very helpful. Here is a portion of the Venue Client log file...
>> 10/07/08 12:40:05 1384 ServiceDiscovery servicediscovery.py:62 INFO Required bonjour libs not found; service discovery disabled
>> 10/07/08 12:40:26 1384 Toolkit config.py:625 DEBUG retrieved local IP address 172.16.10.135
>> 10/07/08 12:40:26 1384 Toolkit toolkit.py:116 DEBUG Initializing AG Toolkit version 3.1
>> 10/07/08 12:40:26 1384 Toolkit toolkit.py:117 INFO Command and arguments: ['C:\\Program Files\\AGTk-3\\bin\\VenueClient3.py']
>> 10/07/08 12:40:26 1384 VenueClient preferences.py:188 DEBUG Preferences.LoadPreferences: open file
>> 10/07/08 12:40:26 1384 Toolkit toolkit.py:166 INFO Logfile Name: VenueClient.log
>> 10/07/08 12:40:26 1384 Toolkit venueclient3.py:137 INFO wx version is: 2.6.3.3
>> 10/07/08 12:40:27 1384 VenueClient venueclient.py:529 DEBUG __StartWebService: service manager: http://172.16.10.135:11000/ServiceManager
>> 10/07/08 12:40:27 1384 VenueClient venueclient.py:543 DEBUG __StartWebService: node service: http://172.16.10.135:11000/NodeService
>> 10/07/08 12:40:27 1384 NodeService agnodeservice.py:640 INFO NodeService.GetConfigurations
>> 10/07/08 12:40:27 1384 VenueClient venueclient.py:270 DEBUG Loading node configuration: <AccessGrid.Descriptions.NodeConfigDescription instance at 0x01FF65F8>
>> 10/07/08 12:40:27 1384 NodeService agnodeservice.py:379 INFO NodeService.LoadConfiguration
>> 10/07/08 12:40:27 1384 NodeService agnodeservice.py:398 INFO Trying to load node configuration from: C:\Program Files\AGTk-3\Config\nodeConfig\default
>> 10/07/08 12:40:27 1384 NodeService agnodeservice.py:406 DEBUG section: node
>> 10/07/08 12:40:27 1384 NodeService agnodeservice.py:408 DEBUG servicemanagers : servicemanager0
>> 10/07/08 12:40:27 1384 NodeService agnodeservice.py:406 DEBUG section: service1
>> 10/07/08 12:40:27 1384 NodeService agnodeservice.py:408 DEBUG packageName : VideoConsumerService.zip
>> 10/07/08 12:40:27 1384 NodeService agnodeservice.py:406 DEBUG section: service0
>> 10/07/08 12:40:27 1384 NodeService agnodeservice.py:408 DEBUG packageName : AudioService.zip
>> 10/07/08 12:40:27 1384 NodeService agnodeservice.py:408 DEBUG serviceConfig : serviceconfig0
>> 10/07/08 12:40:27 1384 NodeService agnodeservice.py:406 DEBUG section: servicemanager0
>> 10/07/08 12:40:27 1384 NodeService agnodeservice.py:408 DEBUG url :
>> 10/07/08 12:40:27 1384 NodeService agnodeservice.py:408 DEBUG builtin : 1
>> 10/07/08 12:40:27 1384 NodeService agnodeservice.py:408 DEBUG services : service0 service1
>> 10/07/08 12:40:27 1384 NodeService agnodeservice.py:408 DEBUG name :
>> 10/07/08 12:40:27 1384 NodeService agnodeservice.py:406 DEBUG section: serviceconfig0
>> 10/07/08 12:40:27 1384 NodeService agnodeservice.py:408 DEBUG Force AC97 : False
>> 10/07/08 12:40:27 1384 NodeService agnodeservice.py:408 DEBUG Silence Suppression : Off
>> 10/07/08 12:40:27 1384 NodeService agnodeservice.py:408 DEBUG Output Gain : 50
>> 10/07/08 12:40:27 1384 NodeService agnodeservice.py:408 DEBUG Talk : Off
>> 10/07/08 12:40:27 1384 NodeService agnodeservice.py:408 DEBUG Input Gain : 50
>> 10/07/08 12:40:27 1384 NodeService agnodeservice.py:483 DEBUG using builtin service manager at http://172.16.10.135:11000/ServiceManager
>> 10/07/08 12:40:27 2272 ServiceManager agservicemanager.py:210 INFO AGServiceManager.RemoveServices
>> 10/07/08 12:40:27 3228 ServiceManager agservicemanager.py:103 INFO AGServiceManager.AddService
>> 10/07/08 12:40:27 3228 ServiceManager agservicemanager.py:132 INFO Extracting service package to C:\Documents and Settings\administrator\Application Data\AccessGrid3\local_services\AudioService
>> 10/07/08 12:40:27 3228 ServiceManager agservicemanager.py:378 DEBUG Executing service AudioService
>> 10/07/08 12:40:27 3228 ServiceManager agservicemanager.py:410 INFO Running Service; options: ['C:\\Documents and Settings\\administrator\\Application Data\\AccessGrid3\\local_services\\AudioService\\AudioService.py', '--port', 59743, '--serviceManagerUri', 'http://172.16.10.135:11000/ServiceManager', '--token', '0001000401687c0a20adc8195931c128']
>> 10/07/08 12:40:27 3228 ProcessManager processmanager.py:62 DEBUG Creating process: C:\Python24\pythonw.exe "C:\Documents and Settings\administrator\Application Data\AccessGrid3\local_services\AudioService\AudioService.py" --port 59743 --serviceManagerUri http://172.16.10.135:11000/ServiceManager --token 0001000401687c0a20adc8195931c128
>> 10/07/08 12:40:27 3228 ProcessManager processmanager.py:75 DEBUG Create process returns: (<PyHANDLE:1028>, <PyHANDLE:1040>, 2212, 3524)
>> 10/07/08 12:40:37 3228 ServiceManager agservicemanager.py:424 INFO Service failed to register: 0001000401687c0a20adc8195931c128
>> 10/07/08 12:40:37 3228 Hosting servicecontainer.py:17 ERROR Processing Failure
>> exceptions:Exception
>> Service failed to become reachable
>> [trace: C:\Python24\lib\site-packages\ZSI\ServiceContainer.py:108:_Dispatch
>> C:\Python24\lib\site-packages\AccessGrid3\AccessGrid\interfaces\AGServiceManager_interface.py:960:soap_AddServiceByName
>> C:\Python24\lib\site-packages\AccessGrid3\AccessGrid\AGServiceManager.py:97:AddServiceByName
>> C:\Python24\lib\site-packages\AccessGrid3\AccessGrid\AGServiceManager.py:147:AddService
>> C:\Python24\lib\site-packages\AccessGrid3\AccessGrid\AGServiceManager.py:425:__ExecuteService]
>> 10/07/08 12:40:37 1384 NodeService agnodeservice.py:518 ERROR Exception adding service AudioService.zip
>> Traceback (most recent call last):
>> File "C:\Python24\lib\site-packages\AccessGrid3\AccessGrid\AGNodeService.py", line 515, in LoadConfiguration
>> prefs.GetProfile())
>> File "C:\Python24\lib\site-packages\AccessGrid3\AccessGrid\interfaces\AGServiceManager_client.py", line 60, in AddServiceByName
>> response = self.binding.Receive(AddServiceByNameResponse.typecode)
>> File "C:\Python24\lib\site-packages\ZSI\client.py", line 504, in Receive
>> return _Binding.Receive(self, replytype, **kw)
>> File "C:\Python24\lib\site-packages\ZSI\client.py", line 432, in Receive
>> raise FaultException(msg)
>> FaultException: Processing Failure
>> 10/07/08 12:40:37 3864 ServiceManager agservicemanager.py:103 INFO AGServiceManager.AddService
>> 10/07/08 12:40:37 3864 ServiceManager agservicemanager.py:132 INFO Extracting service package to C:\Documents and Settings\administrator\Application Data\AccessGrid3\local_services\VideoConsumerService
>> 10/07/08 12:40:37 3864 ServiceManager agservicemanager.py:378 DEBUG Executing service VideoConsumerService
>> 10/07/08 12:40:37 3864 ServiceManager agservicemanager.py:410 INFO Running Service; options: ['C:\\Documents and Settings\\administrator\\Application Data\\AccessGrid3\\local_services\\VideoConsumerService\\VideoConsumerService.py', '--port', 51018, '--serviceManagerUri', 'http://172.16.10.135:11000/ServiceManager', '--token', '0001000401687c0a24b3d9e38373be44']
>> 10/07/08 12:40:37 3864 ProcessManager processmanager.py:62 DEBUG Creating process: C:\Python24\pythonw.exe "C:\Documents and Settings\administrator\Application Data\AccessGrid3\local_services\VideoConsumerService\VideoConsumerService.py" --port 51018 --serviceManagerUri http://172.16.10.135:11000/ServiceManager --token 0001000401687c0a24b3d9e38373be44
>> 10/07/08 12:40:37 3864 ProcessManager processmanager.py:75 DEBUG Create process returns: (<PyHANDLE:12>, <PyHANDLE:1044>, 3832, 4080)
>> 10/07/08 12:40:47 560 ServiceManager agservicemanager.py:234 INFO Service registered: token,url = 0001000401687c0a20adc8195931c128,http://172.16.10.135:59743/Services/AudioService.0001000408a47c0a289309db6b1c8b07
>> 10/07/08 12:40:47 3864 ServiceManager agservicemanager.py:422 INFO Service registered: None 0001000401687c0a24b3d9e38373be44
>> 10/07/08 12:40:47 3864 Hosting servicecontainer.py:17 ERROR Processing Failure
>> exceptions:AttributeError
>> 'NoneType' object has no attribute 'find'
>> C:\Python24\lib\site-packages\AccessGrid3\AccessGrid\AGServiceManager.py:150:AddService
>> C:\Python24\lib\site-packages\AccessGrid3\AccessGrid\interfaces\AGService_client.py:210:SetPackageFile
>> C:\Python24\lib\site-packages\ZSI\client.py:250:Send
>> C:\Python24\lib\urlparse.py:50:urlparse
>> C:\Python24\lib\urlparse.py:89:urlsplit]
>> 10/07/08 12:40:47 1384 NodeService agnodeservice.py:518 ERROR Exception adding service VideoConsumerService.zip
>> prefs.GetProfile())
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20081009/2ce677e0/attachment.htm>
