[AG-TECH] AG bridge woes
Thomas D. Uram
turam at mcs.anl.gov
Fri Nov 7 13:44:28 CST 2008
If there's any state in the bridge log file when it becomes
unresponsive, a bug should definitely be filed. VenueClient logs that
indicate the bridge failure would also be helpful. If no related
information appears in the log file, we should try to instrument the
bridge code to catch the problem. If you're willing to help with such
an effort, either coding or running a modified bridge, say so and we'll
try to resolve this problem.
Tom
On 11/6/08 12:33 PM, Todd Zimmerman wrote:
> On Sun, 2008-11-02 at 19:15 -0500, Gurcharan S. Khanna wrote:
>> all,
>> i have to agree with jeremy's point, that to the outside world and the
>> 'powers that be',
>> that this kind of behavior makes AG look unstable, unreliable, and
>> dubious to invest in.
>> it's certainly something that ought to rise in priority to 'fix' as
>> otherwise it will remain an
>> obstacle to wider acceptance and even funding.
> As a person that has run a venueserver/bridgeserver since 2002ish, I've
> actually found them to be quite stable. That is not to say that there
> haven't been issues, and that I haven't set up typical server
> infrastructure (nightly backups of configs etc) - but overall I've had
> to spend very little time the management of my servers.
> I have instituted the nightly restarts not because they require nightly
> restarts - but because they may require to be restarted on a biweekly
> basis (perhaps) or more. To me, putting in a 4 line crontab to run
> nightly is a pretty simple way to ease my mind and ensure stability.
> With this in place, I typically don't have to spend any time managing my
> servers at all...
>> on a related note, i continue to experience venue clients needing to be
>> restarted or venues
>> re-entered every day or so. i leave my nodes up and in the venue 24/7 in
>> public places but
>> that means as likely as not, the public sees error messages instead of
>> nice video. i too have
>> started to re-started the whole machine to make sure it's up and
>> running, but this is surely
>> a workaround to a more basic problem that the system is not robust or
>> reliable. it's especially
>> difficult since i have 6-7 nodes on campus and am trying to deploy more.
> To help determine the cause, we'll need the log files. We need to
> determine exactly what is failing (network connection to the venue? the
> venueserver, the venueclient??) What is the error message you are
> receiving??
> Cheers,
> Todd
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20081107/b83b2190/attachment.htm>
