[AG-TECH] h.264 vic
Thomas D. Uram
turam at mcs.anl.gov
Fri May 2 14:37:55 CDT 2008
Gurcharan:
You might have better luck with the HD-compatible RAT that Doug mentions
here:
http://www.mcs.anl.gov/web-mail-archive/lists/ag-tech/2007/12/msg00017.html
Tom
> Piers,
> the problem is that RAT doesn't see ANY audio devices. now, i recall
> there was something
> about HD issues. the driver is a SoundMax HD. is that the problem? is
> there a workaround?
> thanks,
> -gurcharan
> Piers O'Hanlon wrote:
>> Hi Gurchan,
> finally, rat shows signal in the listen window but headphones don't pick
>> up any audio. the windows xp system has built in MS RDP audio driver
>> but sometimes switches to SoundMax HD, but neither seem to allow
>> the headphones to connect to the signal RAT is obviously seeing. not
>> an AG issue but maybe someone can give me a clue.
> You can select the appropriate audio device in RAT control menu -
> under 'audio'. If
> you select the audio device you want then you can chekc RAT has kept the setting
> by going back to that page to see if it is still selected.
> Once the device is selected - you may need to play with the audio
> mixer to get the
> right signals coming out the right outputs.
> Piers
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20080502/27acc0ab/attachment.htm>
