[AG-TECH] Single vs multiple machine node?
Christoph Willing
willing at vislab.uq.edu.au
Mon Mar 24 18:48:52 CDT 2008
On 25/03/2008, at 6:49 AM, Dioselin Gonzalez wrote:
> Hello (and greetings to all the people with whom I have worked in
> the past!!),
> In building our nodes I wanted to ask the community your
> thoughts/suggestions/experiences on having a single machine node. We
> wonder if having a quad-core machine (instead of 3 separate audio,
> video and display ones) will be enough for sessions with many
> attendees, streaming MPEG4 and running shared applications. Jason
> Bell reported CPU usage of 40% with 4 video streams
> (http://www-unix.mcs.anl.gov/web-mail-archive/lists/ag-tech/2008/03/
> msg00045.html);
> we are planning to send up to 8 video streams.
You'll certainly need a newer machine to run so many streams - we've
recently been using the Dell T3400 quad-core machines and they're
working very well so far (although not with 8 streams). I believe the
T3400 is the machine that Jason was also testing with. A good feature
of these machines is their dual PCIe graphics slots, enabling 2 high
performance dual output graphics cards to be used.
As for the number of machines, three are almost definitely not
needed. In particular the separate audio machine is not necessary and
complicates day to day operation. We always recommend running the
audio on the display machine - thats the machine the operator is
mostly dealing with to manipulate the video display streams so its
the better place to have the audio control too; then there's no need
to switch between machines. We generally recommend a separate video
capture machine for anything other than personal desktop nodes.
There's is usually only 1 or 2 video streams being captured in
personal nodes. However in the bigger nodes, the proliferation of vic
instances (1 for each capture stream) can be extremely confusing for
the operator. Its better keep the multiple vic instances "hidden" in
a separate capture machine, leaving just a single
VideoConsumerService (and the AudioService) to run on the display
machine.
In summary, it may be technically possible to use a single good
enough machine for everything but its operationally more advisable to
use a display machine (which also handles the audio) along with a
separate video capture machine.
chris
Christoph Willing +61 7 3365 8350
QCIF Access Grid Manager
University of Queensland
