[AG-TECH] AGTk 3.1 - SharedDesktop problem on WINDOWS VISTA
    William Alberto Romero Ramirez
    wil-rome at uniandes.edu.co
    Thu Mar  6 18:54:49 CST 2008
Hi to everybody,
I have been trying to use Shared Desktop (SharedDesktop-v02.1.agpkg3 - RealVNC 4.1.2) with AGTk 3.1 on WINDOWS VISTA but I can't.
When I try to run by Windows console I get:
C:\Users\ISIS3810\AppData\Roaming\ACCESS~1\SHARED~1\SHARED~1>SharedDesktop.py https://ag-mox.uniandes.edu.co:8000/Venues/default/apps/9dfdc0a44a400d711c263eb0d2
e33368
Traceback (most recent call last):
  File "C:\Users\ISIS3810\AppData\Roaming\ACCESS~1\SHARED~1\SHARED~1\SharedDeskt
op.py", line 100, in ?
    from AccessGrid.Version import GetVersion
ImportError: No module named AccessGrid.Version
so I added the line:
sys.path.insert(0,'C:\\Python24\\lib\\site-packages\\AccessGrid3')
and I tried again and I got:
e33368 >> result.txt
03/06/08 19:47:25 3612 Toolkit     toolkit.py:166 INFO  Logfile Name: SharedDesk
top.log
03/06/08 19:47:25 3612 Toolkit     config.py:613 ERROR Error setting hostname.
  File "C:\Python24\lib\site-packages\AccessGrid3\AccessGrid\Config.py", line 60
7, in SetHostname
    sock.bind((hostname, 0))
  File "<string>", line 1, in bind
gaierror: (11001, 'getaddrinfo failed')
03/06/08 19:47:25 3612 Toolkit     config.py:630 ERROR Failed to determine local
 IP address, using 127.0.0.1
  File "C:\Python24\lib\site-packages\AccessGrid3\AccessGrid\Config.py", line 62
4, in _SetHostnameToLocalIP
    self.hostname = self.GetLocalIPAddress()
  File "C:\Python24\lib\site-packages\AccessGrid3\AccessGrid\Platform\win32\Conf
ig.py", line 451, in GetLocalIPAddress
    if parts[0] == "0.0.0.0":
IndexError: list index out of range
03/06/08 19:47:25 3612 Toolkit     toolkit.py:116 DEBUG Initializing AG Toolkit
version 3.1
03/06/08 19:47:25 3612 Toolkit     toolkit.py:117 INFO  Command and arguments: [
'C:\\Users\\ISIS3810\\AppData\\Roaming\\ACCESS~1\\SHARED~1\\SHARED~1\\SharedDesk
top.py', 'https://ag-mox.uniandes.edu.co:8000/Venues/default/apps/9dfdc0a44a400d
711c263eb0d2e33368']
03/06/08 19:47:25 3612 VenueClient     preferences.py:188 DEBUG Preferences.Load
Preferences: open file
top.log
03/06/08 19:47:25 3612 SharedDesktop     shareddesktop.py:962 INFO  SharedDeskto
p.init:Started shared desktop  appUrl https://ag-mox.uniandes.edu.co:8000/Venues
/default/apps/9dfdc0a44a400d711c263eb0d2e33368, venueUrl None, debugMode 1
op.py", line 1521, in ?
    sharedApp = SharedDesktop( args[0],appName=name, debugMode=options.debug )
op.py", line 978, in __init__
    self.serverAddress = SystemConfig.instance().GetLocalIPAddress()
¿ Do I have to configure something on Windows VISTA ?
¿ Some idea about that ?
William A. Romero R.
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20080306/b0e04df0/attachment.htm>
