[AG-TECH] Binding a bridge to a nic
Jon Johansson
jon.johansson at ualberta.ca
Thu Jun 26 13:56:51 CDT 2008
I'm moving my bridge to a new machine and I would like to bind
the bridge process to a particular nic because the other one
is going to be busy doing other stuff. I can't seem to make it
work, though. I've used the 'listenPort' option to the Bridge3.py
where
IPADDRESS="129.128.125.61:23000"
--listenPort=$IPADDRESS
but listenPort is supposed to be an integer, only the port number.
When I run the bridge without this, the ip address of the other
nic appears in the bridge registry.
Is there any way to force the bridge process to use a particular
nic?
Jon.
~~ Jon I Johansson, Ph.D. * Tel.: (780) 492-9304 ~~
~~ jon.johansson at ualberta.ca * Fax.: (780) 492-1729 ~~
~~ * Office: G.S.B. 323C ~~
~~ Programmer/Analyst http://sciviz.aict.ualberta.ca ~~
~~ Research Computing Support ~~
~~ Room 352, General Services Building ~~
~~ Academic Information and Communication Technologies (AICT) ~~
~~ University of Alberta ~~
~~ Edmonton, Alberta, CANADA, T6G 2H1 ~~
! "This communication is intended for the use of the recipient to !
! which it is addressed, and may contain confidential, personal, !
! and/or privileged information. Please contact us immediately !
! if you are not the intended recipient of this communication. !
! If you are not the intended recipient of this communication, !
! do not copy, distribute, or take action on it. Any !
! communication received in error, or subsequent reply, should !
! be deleted or destroyed." !
