[AG-TECH] Renaming service managers
Thomas D. Uram
turam at mcs.anl.gov
Thu Jan 17 10:45:18 CST 2008
Has this problem persisted for you? If so, restart the service manager
components (first making sure that any existing ones have been killed),
and try again. There is some local subnet host discovery (ala Bonjour)
that could account for the problem you're seeing. Either way, if this
is a bug I'd like to make sure it gets addressed.
Tom
On 1/10/08 5:04 PM, Ryan McVeigh wrote:
> The hostnames properly resolve from the display machine in that the
> host machine can find the other. But I'm not sure that the
> configuration is being saved properly or that I'm loading the newly
> saved node config. The only step I've attempted is changing the
> configuration in the AG node management by starting from scratch and
> when I go to fill in the new names in the Add Service Manager Dialog
> box and hit OK the name shows up as it was before within the node
> management window. Is there a step I am missing?
> Thanks,
> Ryan McVeigh
> National Center for Atmospheric Research
> On Jan 10, 2008, at 3:54 PM, Thomas D. Uram wrote:
>> I'm sure the AG software is not meddling with the hostnames, as it
>> does no special caching of hostnames or anything. Two things come to
>> mind:
>> - Are you sure that the node configuration is being saved properly,
>> using the new names? Are you sure you are loading the newly saved
>> node configuration?
>> - Do the new hostnames properly resolve from the display machine?
>> Tom
>> On 1/10/08 4:42 PM, Ryan McVeigh wrote:
>>> Hey everyone,
>>> Our network team changed our network to DHCP over the holidays and
>>> changed the network names of our multi-node system. Now neither pc
>>> can find each other within the Access Grid software. If I try to
>>> create a new configuration in AG node management it changes the
>>> name/IP to the name used prior to the network change.
>>> How do you rename the service managers/computers within the AG
>>> software so that they recognize each other?
>>> Thanks,
>>> Ryan McVeigh
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20080117/7ad1c5df/attachment.htm>
