[AG-TECH]Install AG2.x and AG3.x on a two box node?
    Jason Bell
    j.bell at cqu.edu.au
    Wed Jan  2 03:07:48 CST 2008
G'day John
Being able to run both AG 2 and/or 3 on a multinode setup is relatively simple.
Basically what you need to be able to do is run 2.x and 3.x AGServiceManagers at the same time.
On my Linux Install guide (http://www.accessgrid.org/node/879) , there is a section "Running AG2 and AG3 Service Managers Together (Multi-Node Configuration Only)" which can be found at http://www.accessgrid.org/node/889.
Even though you are running Windows as the display machine, this guide is directly applicable, as it shows how to enable the user to execute either Access Grid VenueClient (which in this case will be on a windows system) without requiring to shutdown one service manager and starting the other one on your Linux system.
I hope this helps.
Cheers,
Jason.
From: john langkals [mailto:langkals at pacific.mps.ohio-state.edu]
Sent: Wednesday, 2 January 2008 3:31 PM
To: ag-tech at mcs.anl.gov
Subject: [AG-TECH]Install AG2.x and AG3.x on a two box node?
Hello AG Tech,
Question: My main AG node is running the display in XP and the audio/video capture is on a Fedora Core box, as this is a dual box environment, can I install but not run simultaneously, AG 2.x and AG 3.x?  I know it's easy enough on a AG PIG, but can this be extended to a dual node mixed environment setup?
Thank you,
John
John Langkals
Systems Manager
Smith Seminar Room
Department of Physics
The Ohio State University
PRB 1080 Physics Research Building
191 West Woodruff Avenue
Columbus, Ohio 43210
614.292.6957 Office
614.327.3732 Cell
614.292.7557 FAX
www.octs.osu.edu
