[AG-TECH] AGVCR-saving edited program
Jason Bell
j.bell at cqu.edu.au
Sun Feb 24 22:19:22 CST 2008
G'day Akos
Basically what you need to do is select the "edit" tab within AGVCR, as
this will allow you to edit the recording and save as a different name.
The following website might also be useful for you as well
http://iri.informatics.indiana.edu/%7Edcpiper/agvcr/docs.php#editing.
Additionally, if you just want to capture the audio, you might be
interested to know that "rat" can capture the audio and save it as a
"wav" file.
Hope this helps.
Cheers,
Jason.
-----Original Message-----
From: akos at wasp.uwa.edu.au [mailto:akos at wasp.uwa.edu.au]
Sent: Monday, 25 February 2008 12:25 PM
To: ag-tech at mcs.anl.gov
Subject: [AG-TECH] AGVCR-saving edited program
Dear All,
I want to save the audio only from the recordings. I have set the
channels
accordingly but can not see how to save it to a new file.
I set the Output file path/name but there is no save button. There is
the
usual 'file' button behind the 'Output file' textbox but it doesn't have
a
save button, only an 'open' button.
How do I save the selected streams to a new file?
Akos
