[AG-TECH] RE: Problems getting Unicast Bridge to run CentOS 5.0
    Dinale, Justin
    Justin.Dinale at dsto.defence.gov.au
    Mon Aug 25 00:42:43 CDT 2008
At the cost of looking like an idiot, the Bridgeserver it has just
started working again...
For whoever has the same issue:
	Try starting the Bridgeregistry before the Bridgeserver.
There is probably some other issue causing the error (since I was trying
to get the Registry  up before the  server most of the day), in which
case I'd recommend a nice clean OS install.
Cheers,
Justin
IMPORTANT: This email remains the property of the Australian Defence Organisation and is subject to the jurisdiction of section 70 of the CRIMES ACT 1914.  If you have received this email in error, you are requested to contact the sender and delete the email.
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20080825/11614194/attachment.htm>
