[AG-TECH] Firewire Detection Bug on FC7
Jinseung Ryu
jinsryu at gmail.com
Wed Apr 23 19:37:17 CDT 2008
Thanks Doug.
I think you misunderstand my problem for my lossy informations.
I wantto use AG H264 vic service with firewired sony cam. But, this device
is detected by only UQ's vic version not AGTK vic.
UQ's vic version shows 7 devices(Sony HVR-V1N, 4 x v4l-bt878 video, x11,
NoiseGenerator).
AGTK's vic version shows 9 devices (4 x V4L-BT878 video, 4 x V4L2-BT878
video and X11)
I cannot produce H264 video with firewire device on AG.
Thanks in advance
/Ryu
On 4/23/08, Douglas Kosovic <douglask at itee.uq.edu.au> wrote:
> Hi Ryu,
> I have fc7 installed server, it's dell precision 490.
> > It has a 4-head video capture card and ieee1394 card and it's installed
> > agtk3.1 and UQ' advanced video tool.
> > I have seen that the sumover vic(agtk 3.1 vic) can not find the
> > firewire device but UQ's vic can find the firewire device.
> > /dev/raw1394 file exist and it's owner is ag user account.
> > anybody can give some tips. or need more informations to find the
> > solution?
> Jason Bell has done some doco for setting up the firewire support on
> Fedora 7 & 8 here:
> http://www.accessgrid.org/node/1099
> You might want to confirm that the raw1394 driver has been setup correctly
> with /usr/bin/testlibraw and check that you are receiving DV isochronous
> channel packets by running /usr/bin/dumpiso (both of these commands come
> with the libraw1394 RPM). If you are seeing lots of gibberish output with
> dumpiso, then it is working.
> Cheers,
> Doug
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20080424/e5b9674a/attachment.htm>
