[AG-TECH] Bridge Server on Windows XP
Kivshar, Boris (Contractor)
Boris.Kivshar at dsto.defence.gov.au
Sun Apr 20 19:34:41 CDT 2008
Hello,
I have been having the exact same problem on Windows XP / Server 2003
for quite some time now.
I have tried on multiple computers and multiple sites which are on
different network, so it's not a computer / network issue.
I have experimented a bit and it seems to me that I am doing the correct
thing in regards to the installation. It's funny because I was going to
send out the same email as CJ. Attached are the logs from the problem.
Also if anyone wants I have pretty detailed installation instructions on
setting up a venue server (To check if I am installing it correctly),
but for some reason the bridge doesn't work as below. (Let me know if
you need them as I have to de-classify them)
Thanks
Boris Kivshar
IMPORTANT: This email remains the property of the Australian Defence
Organisation and is subject to the jurisdiction of section 70 of the
CRIMES ACT 1914. If you have received this email in error, you are
requested to contact the sender and delete the email.
From: owner-ag-tech at mcs.anl.gov [mailto:owner-ag-tech at mcs.anl.gov] On
Behalf Of Choon Jin Ng
Sent: Sunday, 20 April 2008 4:50 PM
To: ag-tech at mcs.anl.gov
Subject: [AG-TECH] Bridge Server on Windows XP
Hi there!
I've just set up a bridge server in a Windows XP machine. The command to
launch the bridge is:
C:\Python24\python.exe "C:\Program Files\AGTk-3\bin\Bridge3.py"
--name="ViSLAB Bridge" --location="USYD, Sydney, NSW, Australia" -q
"\progra~1\agtk-3\bin\quickbridge.exe"
The problem is it accepts connection for only 1 time. After this, it
will rejects all connections and the client will have an error message
"Connection to bridge failed. Please use a different bridge.".
Is there a bug on the bridge server running on a Windows XP? Thanks.
CJ
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20080421/2ed9f20d/attachment.htm>
Name: UNCLASS Bridge.log
Desc: UNCLASS Bridge.log
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20080421/2ed9f20d/attachment.obj>
Name: UNCLASS VenueServer.log
Desc: UNCLASS VenueServer.log
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20080421/2ed9f20d/attachment-0001.obj>
Name: UNCLASS VenueClient.log
Desc: UNCLASS VenueClient.log
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20080421/2ed9f20d/attachment-0002.obj>
