[AG-TECH] Any more H.264 news?
Douglas Kosovic
douglask at itee.uq.edu.au
Wed Apr 16 19:54:22 CDT 2008
Hi Andrew,
> The only major issues that we're seeing revolve around firewire/dv
> support.
> On Windows, firewire capture shows flashing vertical white lines (as has
> probably already been mentioned on the list), and on Linux (Ubuntu) vic
> can't see any firewire devices, and I have the device permissions set
> correctly as far as I can tell so I don't think the problem would be on my
> end. I'm guessing that the Linux issue is due to the current Linux
> packages
> (from Chris at UQ) not actually including the "enhanced vic" code that
> supports DV and was developed at UQ, but rather just the new
> h.264-supporting code from SUMOVER. Is this correct, and if so, will these
> codebases be merged?
UQ Vislab vic doesn't do any transcoding from DV (or HDV) firewire devices
to other codecs, so if the codebase was merged as it stands now, it wouldn't
do what you are trying to do anyway.
Have you tried using DV4Linux so that your Camcorder can be seen as a V4L
device? I haven't tried it myself.
As for the flashing verticle line artifacts on Windows, I don't seem them,
but I was using a quad-core 2.6GHz Xeon.
Cheers,
Doug
