[AG-TECH] VenueServer only binding on localhost interface (Linux Ubuntu)
Jason Bell
j.bell at cqu.edu.au
Fri Sep 28 05:01:07 CDT 2007
Andreas
As a guess, I would suggest editing your host file, as this may resolve your issue.
See http://www.accessgrid.org/node/778 for instructions (I realise this is for Fedora Core 7, but I believe this should be the same).
Cheers,
Jason.
-----Original Message-----
From: Andreas Bergstrøm [mailto:andreas.bergstrom at hiof.no]
Sent: Friday, 28 September 2007 7:27 PM
To: ag-tech at mcs.anl.gov
Subject: [AG-TECH] VenueServer only binding on localhost interface (Linux Ubuntu)
I am working on setting up a Venue Server (ag.hiof.no), I have
installed the binaries from http://www.vislab.uq.edu.au/research/
accessgrid/software/debian/ and successfully gotten a service
certificate for ag.hiof.no.
However, when I start the VenueServer, it only connects to localhost:
Server: https://127.0.1.1:8000/VenueServer
Data Port: 8006
Default Venue Url: https://127.0.1.1:8000/Venues/default
Has anyone else experienced this? I have tried searching both with
google.com and the mailing lists, but not found anything related.
Any and all help accepted with thanks.
The logs are appended at the bottom.
Andreas Bergstrøm
Østfold University College
