Fwd: RE: [AG-TECH] NAT and bridge traffic
George Estes
gestes at ncsa.uiuc.edu
Tue Sep 11 15:35:47 CDT 2007
Joe,
Would you be willing to share your experience in setting up the OpenVPN/Bridge?
George
>X-Envelope-From: Zsolt-Nagykaldi at ouhsc.edu
>X-Envelope-To: <gestes at ncsa.uiuc.edu>
>Subject: RE: [AG-TECH] NAT and bridge traffic
>Date: Tue, 11 Sep 2007 12:51:27 -0500
>X-MS-Has-Attach:
>X-MS-TNEF-Correlator:
>Thread-Topic: [AG-TECH] NAT and bridge traffic
>Thread-Index: Acf0ljzjI12+VmBDQr2sxHVMjKfGHQABTNuN
>From: "Nagykaldi, Zsolt F. \(HSC\)" <Zsolt-Nagykaldi at ouhsc.edu>
>To: "George Estes" <gestes at ncsa.uiuc.edu>
>Cc: <ag-tech at mcs.anl.gov>
>X-OriginalArrivalTime: 11 Sep 2007 17:51:27.0882 (UTC) FILETIME=[60C30EA0:01C7F49C]
>X-Proofpoint-Virus-Version: vendor=fsecure engine=4.65.5502:2.3.11,1.2.37,4.0.164 definitions=2007-09-11_04:2007-09-11,2007-09-11,2007-09-11 signatures=0
>X-Proofpoint-Spam-Details: rule=notspam policy=default score=0 spamscore=0 ipscore=0 phishscore=0 bulkscore=0 adultscore=0 classifier=spam adjust=0 reason=mlx engine=3.1.0-0708230000 definitions=main-0709110068
>X-Scanned-By: milter-spamc/1.12.383 .383 (rimantadine.ncsa.uiuc.edu [141.142.2.77]); Tue, 11 Sep 2007 12:52:16 -0500
>X-Spam-Status: NO, hits=4.50 required=4.90
>X-Null-Tag: aefa1a49861c3a28f7ff4601584732f4
>X-NCSA-MailScanner-Information: Please contact help at ncsa.uiuc.edu for more information, rimantadine.ncsa.uiuc.edu
>X-NCSA-MailScanner: Found to be clean
>X-Deliver-To: gestes
>OpenVPN allows you to put your remote client computer "physically" and very securely on an ad-hoc local network. Therefore, as the most simple setup, you can run an OpenVPN server on the same machine that you use for the bridge server and handle remote clients as local network clients, allowing access to the bridge for a range of local IPs only (e.g. 10.10.x.x), in addition to your regular bridge access over the Internet. For intricate technical details of fine-tuning the bridge server, I would encourage you to contact Joe at <mailto:stone004 at umn.edu>stone004 at umn.edu.
>Zsolt
>Zsolt Nagykaldi, PhD<?xml:namespace prefix = o ns = "urn:schemas-microsoft-com:office:office" />
>Assistant Professor of Research
>Clinical IT Specialist
>University of <?xml:namespace prefix = st1 ns = "urn:schemas-microsoft-com:office:smarttags" />Oklahoma Health Sciences Center
>Department of Family & Preventive Medicine
>900 N.E. 10th Street
>Oklahoma City, OK 73104
>Phone: (405) 271-8000 ext.1-32208
>Fax: (405) 271-2784
>From: George Estes [mailto:gestes at ncsa.uiuc.edu]
>Sent: Tue 9/11/2007 12:08 PM
>To: Nagykaldi, Zsolt F. (HSC)
>Cc: ag-tech at mcs.anl.gov
>Zsolt,
> What's the basic setup for using OpenVPN with a bridge?
>Thanks,
>George
>At 10:46 AM 9/11/2007 -0500, Nagykaldi, Zsolt F. \(HSC\) wrote:
>>It is generally a pain in the back to establish connections to bridge servers in a NAT -ed environment. Port forwarding is one of your options, however there are a number of issues: 1) A large number of ports may need to be forwarded depending on the bridge setup and how many bridges you want to access (security implications); 2) Some older Cisco firewalls without a decent GUI may give you a hard time to create the appropriate rules to do what you need.
>>My suggestion is to forget about ports and use OpenVPN on the bridge and the client machine to go through the NAT -ed network and everything in between your computer and the bridge. We have a significant experience with this and pretty good results. Your absolute expert (who came up with the combined bridge/Open VPN server solution) is Joe Stone (<mailto:stone004 at umn.edu>stone004 at umn.edu). I can also help, if needed.
>>Zsolt
>>Fax: (405) 271-2784
>>From: owner-ag-tech at mcs.anl.gov on behalf of George Estes
>>Sent: Tue 9/11/2007 9:00 AM
>>To: ag-tech at mcs.anl.gov
>>Subject: [AG-TECH] NAT and bridge traffic
>>Hello,
>> Could someone with experience in this area tell me the issues/problems with receiving traffic from a bridge server if I'm behind a NAT. I've looked through the ag-tech mailing list and there's talk of problems but I can't find specifics.
>>Thanks,
>>George
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20070911/aac43493/attachment.htm>
