[AG-TECH] Voiceactivated Video Switching in AG3
Mike Daley
Mike.W.Daley at cs.cardiff.ac.uk
Wed Sep 5 04:03:03 CDT 2007
Hi Tom
The work I talked about at the retreat with the carousel idea has audio
switching partially working. The original idea was to have the current
site speaking bought to the front of the carousel. I know people were
not particularly intested in the revolving carousel as such but the
general principle could be used to auto place the video say around the
screen and have the current active audio premoted to the centre. If
people are interested I could modify my code.
All the best
Mike
Thomas D. Uram wrote:
> Hi Pedro:
> I came across this mail from about a year ago, and wanted to ask
> whether you have worked on this at all.
> I'd be interested to see a solution in this space, and would be
> willing to answer any questions that came up.
> Thanks,
> Tom
> On 6/29/06 10:32 AM, Pedro Maló wrote:
>> I want to do voiceactivated video switching.
>> I've seen that RAT/VIC have a "coordinating mechanism", by using the
>> LBL Conference Bus in both tools.
>> Voice Switching in VIC (from VIC manual):
>> You need VIC v.2.8 and RAT v.3.0.8 (or later), and you need to enable
>> LBL Conference Bus support in both tools:
>> *) rat -lbl_channel x <address/port>
>> *) vic -I x <address/port>
>> where x is replaced by the Conference Bus channel, which is a number
>> between 1 and 300 and must be unique for all sessions running
>> on your machine. In VIC, you must then bring up a single large
>> participant window (by clicking on one of the thumbnail sized imaged).
>> On the enlarged window, select Modes… and voice-switched. If you
>> bring up multiple windows, it should display the last few speakers.
>> -I: Use the small integer channel, which must be non-zero, as the
>> channel identifier for group interprocess communication on the
>> local host. This value should be consistent across each group of
>> applications that belong to a single conference, and should be
>> unique across conferences. SDR will allocate appropriate values. (VIC
>> and RAT currently use this mechanism to coordinate
>> voiceactivated video switching.)
>> I've looked into AG3 services and did not find AG using this option.
>> Have anyone tried it, or is people using another solution to this?
>> Regards,
>> Pedro Malo.
