[AG-TECH] Problems with Access Grid 3.0.2
Nico
nmolina at cesga.es
Thu Oct 18 02:24:57 CDT 2007
Hi Chris!
When I start VenueServer manually I use the same command as in the
script file. The syntax is the same. I have a little script (called
venue_server) in /home/ag/venue_server3 with this line:
VenueServer -c VenueServer.cfg -p 9000 &
So, I just execute at this way: ./venue_server with "ag" user.
The entry for 'persistenceFilename' in VenueServer.cfg is 'VenueServer.dat'
persistenceFilename = VenueServer.dat
Nico.
Christoph Willing escribió:
> On 18/10/2007, at 12:33 AM, Nico wrote:
>> Hi Chris!
>> Thanks for answering! When I start from the script in init.d and I
>> connect a client and I can see all Venues, but I can't enter in any
>> of them because I obtain the error messages I mentioned in the first
>> mail.
>> In the script I have a line different than you to execute
>> VenueServer, but I've specified the "ag" user:
>> daemonAG --user ag VenueServer -c
>> /home/ag/venue_server3/VenueServer.cfg -p 9000
> Nico,
> When you start the server manually and clients can connect to all
> venues, which directory are you starting from? With the line above
> there may be a problem with which VenueServer.dat file is used. What
> is the entry for 'persistenceFilename' in your
> /home/ag/venue_server3/VenueServer.cfg file?
> chris
>> Maybe our scripts are different. I used the syntax from this forum:
>> http://www-unix.mcs.anl.gov/web-mail-archive/lists/ag-tech/2006/02/msg00023.html
>> VenueServer for version 2.4 runs ok with the same syntax.
>> Thanks again for your help! See you soon!
>> Nico.
>>> On 17/10/2007, at 9:53 PM, Nico wrote:
>>>> Hi!
>>>> In our company we have an AG Server on a Linux Fedora Core 4
>>>> machine with Access Grid 3.0.2 installed. We have several Venues
>>>> configured. During these days I've been configuring start scripts
>>>> on the /etc/init.d folder to automatically run Venue Server at the
>>>> start of the system. So the proccess VenueServer is ok when I
>>>> reboot the machine, but when I connect a client I can connect to
>>>> https://server:9000/Venues/default but I can't enter in any
>>>> configured Venue on the server, I try it, but I receive the
>>>> following error message: "Error entering venue".
>>>> So the quick solution is start Venue Server again manually, then I
>>>> can enter in any Venue.
>>>> Could somebody tell me what can happen?
>>> Nico,
>>> Are the additional venues you've created actually visible to the
>>> client when the server is started from the init.d script?
>>> If not, then my guess is that whenever the server is started from
>>> the script in init.d directory, it is being run by the root user
>>> instead of the ordinary user who created the additional venue
>>> structure. In that case the server starts in the wrong directory and
>>> doesn't find the VenueServer.dat file that contains your venue
>>> structure (which was created when you ran the server as an ordinary
>>> user).
>>> Your init.d script should explicitly cd to the directory containing
>>> the correct VenueServer.dat file. It should also su to an ordinary
>>> user account to actually run the venue server.
>>> Here is the crucial line in our startup script which starts the
>>> server. You can see the cd to the directory which contains the
>>> VenueServer.dat file and if that succeeds it runs VenueServer3.py as
>>> the user 'ag' (not root).
>>> cd /var/lib/ag/server_HALL && su ag -c /usr/bin/VenueServer3.py &
>>> Since you run Fedora, I think your executable will be just
>>> 'VenueServer' (rather than 'VenueServer3.py')
>>> chris
>>> Christoph Willing +61 7 3365 8350
>>> QCIF Access Grid Manager
>>> University of Queensland
