[AG-TECH] Problems with Access Grid 3.0.2
Nico
nmolina at cesga.es
Wed Oct 17 09:33:12 CDT 2007
Hi Chris!
Thanks for answering! When I start from the script in init.d and I
connect a client and I can see all Venues, but I can't enter in any of
them because I obtain the error messages I mentioned in the first mail.
In the script I have a line different than you to execute VenueServer,
but I've specified the "ag" user:
daemonAG --user ag VenueServer -c
/home/ag/venue_server3/VenueServer.cfg -p 9000
Maybe our scripts are different. I used the syntax from this forum:
http://www-unix.mcs.anl.gov/web-mail-archive/lists/ag-tech/2006/02/msg00023.html
VenueServer for version 2.4 runs ok with the same syntax.
Thanks again for your help! See you soon!
Nico.
Christoph Willing escribió:
> On 17/10/2007, at 9:53 PM, Nico wrote:
>> Hi!
>> In our company we have an AG Server on a Linux Fedora Core 4 machine
>> with Access Grid 3.0.2 installed. We have several Venues configured.
>> During these days I've been configuring start scripts on the
>> /etc/init.d folder to automatically run Venue Server at the start of
>> the system. So the proccess VenueServer is ok when I reboot the
>> machine, but when I connect a client I can connect to
>> https://server:9000/Venues/default but I can't enter in any
>> configured Venue on the server, I try it, but I receive the following
>> error message: "Error entering venue".
>> So the quick solution is start Venue Server again manually, then I
>> can enter in any Venue.
>> Could somebody tell me what can happen?
> Nico,
> Are the additional venues you've created actually visible to the
> client when the server is started from the init.d script?
> If not, then my guess is that whenever the server is started from the
> script in init.d directory, it is being run by the root user instead
> of the ordinary user who created the additional venue structure. In
> that case the server starts in the wrong directory and doesn't find
> the VenueServer.dat file that contains your venue structure (which was
> created when you ran the server as an ordinary user).
> Your init.d script should explicitly cd to the directory containing
> the correct VenueServer.dat file. It should also su to an ordinary
> user account to actually run the venue server.
> Here is the crucial line in our startup script which starts the
> server. You can see the cd to the directory which contains the
> VenueServer.dat file and if that succeeds it runs VenueServer3.py as
> the user 'ag' (not root).
> cd /var/lib/ag/server_HALL && su ag -c /usr/bin/VenueServer3.py &
> Since you run Fedora, I think your executable will be just
> 'VenueServer' (rather than 'VenueServer3.py')
> chris
> Christoph Willing +61 7 3365 8350
> QCIF Access Grid Manager
> University of Queensland
