[AG-TECH] Dropping OSS device in Rat (Linux)
monika.k.rabarison at jsums.edu
Thu Nov 1 08:30:41 CDT 2007
Hello Jason,
The "easiest way" is the one I am familiar with. However, for some reason,
it did not work on this node.
I edited .RATdefaults as you suggested and RAT is now fine.
Monika
> G'day Monika
> There are a number of ways to "force" the use of an input device.
> Basically there is a .RATdefaults file within your home directory that
> sets the "audioInputPort". Example:
> *audioInputPort: Microphone
> The easiest way to configure this, is to set the input device in rat and
> then "quit" manually, as it will save the settings to this file.
> You could then disable, then re-enable the audio using the
> "Enable/disable audio" button on the Venue Client. Hopefully the input
> device should now be configured correctly... Note, due to the way the
> AG shuts down Rat, it doesn't actually save your setting, so every time
> you changed venues, it would set the input device back to it's default.
> I hope this clarifies the issue you are having.
> Cheers,
> Jason.
> -----Original Message-----
> From: monika.k.rabarison at jsums.edu [mailto:monika.k.rabarison at jsums.edu]
> Sent: Wednesday, 31 October 2007 11:46 PM
> To: Ben.Green at manchester.ac.uk
> Cc: Jason Bell; ag-tech; accessgrid-l at clix.aarnet.edu.au
> Subject: RE: [AG-TECH] Dropping OSS device in Rat (Linux)
> Hello,
> I don't get the issue either
> I also have ALSA as default on Fedora 7. Both ALSA and OSS work fine.
> However, what currently bothering me is that on one of the nodes anytime
> I
> change venue, "Line" switches to "Mic".
> -Monika
>> Hi Jason,
>> I don't get this issue luckily, my OSS device is always there
> alongside
>> the ALSA one. I use the ALSA as default. I'm running FC7.
>> But I do see a similar issue when starting the video producer service,
> and
>> it can take 10 seconds for it to recognise my video device (I just get
> a
>> blank in the drop down device menu). I'm sure other people have seen
> this
>> too.
>> I would image getting vic to sleep for 10 seconds before starting
> would
>> resolve this, in a similar way to how your shell script makes rat wait
> a
>> bit longer before starting (I assume that's what it's doing).
>> Cheers, Ben.
>> | Ben Green |
>> | Access Grid Support Centre |
>> | Room G49-H |
>> | Research Computing Services |
>> | Kilburn Building |
>> | University of Manchester |
>> | Oxford Road |
>> | Manchester |
>> | M13 9PL |
>> | Tel. 0161 306 6621 |
>> | Fax. 0161 275 0637 |
>> | ben.green at manchester.ac.uk |
>> | http://www.agsc.ja.net |
>> From: owner-ag-tech at mcs.anl.gov [mailto:owner-ag-tech at mcs.anl.gov] On
>> Behalf Of Jason Bell
>> Sent: 31 October 2007 05:56
>> To: ag-tech; accessgrid-l at clix.aarnet.edu.au
>> Subject: [AG-TECH] Dropping OSS device in Rat (Linux)
>> G'day all
>> This is just a quick email to see if anyone else has been experiencing
>> an issue that I have been having lately.
>> Basically on my "Linux" systems (Fedora Core 6 and Fedora 7),
> sometimes
>> when Rat is started, the Device "OSS" device is missing in which is
> then
>> defaulted to an "ALSA" device.
>> The reason why this is an issue is the "OSS" device produces far
>> superior audio quality, when compared to "ALSA" (Though I realize that
>> "OSS" is just a wrapper on ASLA with the default Fedora Kernel).
>> From my understanding, the reason why this occurs is that, if the OSS
>> device is in use, it then becomes unavailable and no longer displayed
> as
>> a device, as OSS only allows one application exclusive access.
>> Anyway, from doing some basic testing, it was seen that events like
>> switching from one venue to another was causing this to happen. It
>> appeared that if the machine was heavily loaded, this would increase
> the
>> chance of this happening.
>> Anyway, to cut a long story short, I deleted the /usr/bin/rat sym link
>> and replaced it with a basic shell script:
>> #! /bin/sh
>> sleep 5
>> exec /usr/bin/rat-4.4.00 "$@"
>> From some initial testing, it appears to have fixed the issue! (More
>> testing is required)
>> I'm just wondering if anyone else has experienced this issue with
> Fedora
>> or other Linux systems???
>> Thanks for your time,
>> Jason.
>> Jason Bell, B.I.T.
>> B. Info. Tech. (Honours) Student
>> High Performance Computing Support Officer,
>> Network Engineer
>> Information Technology Division
>> Central Queensland University
>> E-mail : j.bell at cqu.edu.au
>> Phone : 07 4930 9229
>> Patience is a virtue.
>> But if I wanted Patience,
>> I would have become a Doctor.
