[AG-TECH] Not finding Firewire DV on UQ advanced vic
Andrew Ford
acf0659 at rit.edu
Fri May 25 16:57:08 CDT 2007
Thanks Chris, sending DV seems to work fine now. The problem now is that
when I try and receive it (on another machine) the receiving vic hard
freezes (there's the listing for the video with a black thumbnail, and the
window is completely frozen - I have to kill the process to stop it). I'll
attempt to leave the stream sending (to RIT's AG multicast video address,
224.2.224.225/20002) over the weekend, so if anyone could try receiving it,
that would be awesome.
--Andrew
On 5/24/07, Christoph Willing <willing at vislab.uq.edu.au> wrote:
> On 25/05/2007, at 8:03 AM, Andrew Ford wrote:
> > HI,
> > I've been testing out the UQ vic with DV, but it can't seem to find
> > my camera. It can be seen by my machine (at /dev/dv1394/0), and it
> > works (i can cat the stream to a file and play it with mplayer),
> > but it is absent from the vic devices list and doing -D /dev/
> > dv1394/0 doesn't seem to do anything (I assume this was what was
> > meant by 'manually specifying the camera' in the documentation). I
> > have libiec61883-dev and as far as I know I compiled vic with that
> > support. I'm running Ubuntu Linux 6.10 (side note - I get a 404 for
> > http://www.vislab.uq.edu.au/research/accessgrid/software/advideo/
> > ubuntu.html)
> Andrew,
> The 404 should be corrected now.
> That page has some timps about access to the /dev/raw1394 device
> which is what is needed in this case.
> One other thing is to ensure the correct vic is actually being run -
> cd into thye vic directory and run:
> ./vic ......
> rather than just
> vic ......
> chris
> Christoph Willing +61 7 3365 8350
> QCIF Access Grid Manager
> University of Queensland
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20070525/d20463a2/attachment.htm>
