[AG-TECH] Rat and MBUS problems
Lassi Ylikojola
lapeyl at uwasa.fi
Thu May 24 04:21:01 CDT 2007
Hi !
I used to have this problem with rat 4.2.22 on fedora 6 64-bit em64t
with m-audio 2496 / ice1712 card.
The way i 'fixed' it was I installed old soundblaster card on the same
machine and even if it was not default the mixer would start to work
on m-audio.
Anyway never rat from SUMOVER and alsa 1.0.14-0.1.rc1 works for me.
You have to remove the -S option lines from AudioService.py to use
SUMOVER rat.
Lassi
Quoting Jeremy Mann <jeremymann at gmail.com>:
> On 5/23/07, Colin Perkins <csp at csperkins.org> wrote:
>> Mbus problems are often due to a host firewall blocking UDP port
>> 47000. Did you enable a different firewall configuration when rebooting?
> No, no firewalls on either machine. The odd thing was thing was that I
> replaced the soundcard in one Linux machine and the MBUS errors went
> away. I'm now trying to use the SUMOVER's version of RAT to see if
> that fixes the other clients.
