[AG-TECH] Errors in "_ptr [BIO.py:32]" when run VenueClient in cvs.
刘冠强
liugq at vrlab.buaa.edu.cn
Tue May 15 04:21:54 CDT 2007
hi:
I run venueclient in CVS.
I set
AGTK_LOCATION: E:\eclipse-project\AccessGrid
PYTHONPATH: E:\eclipse-project\AccessGrid
But there are errors:
pydev debugger
05/15/07 16:53:55 7736 Toolkit toolkit.py:166 INFO Logfile Name: VenueClient.log
05/15/07 16:53:55 7736 Toolkit config.py:625 DEBUG retrieved local IP address 219.224.167.192
05/15/07 16:53:55 7736 Toolkit toolkit.py:116 DEBUG Initializing AG Toolkit version 3.0.2
05/15/07 16:53:55 7736 Toolkit toolkit.py:117 INFO Command and arguments: ['E:\\eclipse-project\\AccessGrid\\bin\\VenueClient.py', '-d']
05/15/07 16:53:55 7736 VenueClient preferences.py:188 DEBUG Preferences.LoadPreferences: open file
05/15/07 16:53:55 7736 Toolkit venueclient.py:123 INFO wx version is: 2.6.2.1
05/15/07 16:53:56 7736 VenueClient venueclient.py:462 DEBUG __StartWebService: venueclient: http://219.224.167.192:11000/VenueClient
05/15/07 16:53:56 7736 VenueClient venueclient.py:473 DEBUG __StartWebService: service manager: http://219.224.167.192:11000/ServiceManager
05/15/07 16:53:56 7736 VenueClient venueclient.py:487 DEBUG __StartWebService: node service: http://219.224.167.192:11000/NodeService
05/15/07 16:53:56 7736 NodeService agnodeservice.py:638 INFO NodeService.GetConfigurations
05/15/07 16:53:56 7736 VenueClient venueclient.py:233 DEBUG Null node configuration, not loading
05/15/07 16:53:56 7736 VenueClient venueclient.py:321 DEBUG get bridges from registry
05/15/07 16:53:56 7736 VenueClient venueclient.py:327 DEBUG Trying bridge registry: http://www.accessgrid.org/registry/peers.txt
05/15/07 16:53:56 7736 VenueClient preferences.py:188 DEBUG Preferences.LoadPreferences: open file
05/15/07 16:54:17 7736 VenueClient venueclient.py:338 ERROR LoadBridges: Can not connect to bridge registry http://www.accessgrid.org/registry/peers.txt
Traceback (most recent call last):
File "E:\eclipse-project\AccessGrid\AccessGrid\VenueClient.py", line 331, in LoadBridges
bridgeList = self.registryClient.LookupBridge()
File "E:\eclipse-project\AccessGrid\AccessGrid\Registry\RegistryClient.py", line 158, in LookupBridge
self._connectToRegistry()
File "E:\eclipse-project\AccessGrid\AccessGrid\Registry\RegistryClient.py", line 85, in _connectToRegistry
self.registryPeers = self._readPeerList(url=self.url)
File "E:\eclipse-project\AccessGrid\AccessGrid\Registry\RegistryClient.py", line 194, in _readPeerList
f = urllib.urlopen(url)
File "C:\PYTHON23\lib\urllib.py", line 76, in urlopen
return opener.open(url)
File "C:\PYTHON23\lib\urllib.py", line 181, in open
return getattr(self, name)(url)
File "C:\PYTHON23\lib\urllib.py", line 297, in open_http
h.endheaders()
File "C:\Python23\lib\httplib.py", line 715, in endheaders
self._send_output()
File "C:\Python23\lib\httplib.py", line 600, in _send_output
self.send(msg)
File "C:\Python23\lib\httplib.py", line 567, in send
self.connect()
File "C:\Python23\lib\httplib.py", line 551, in connect
raise socket.error, msg
IOError: [Errno socket error] (10060, 'Operation timed out')
05/15/07 16:54:17 7736 VenueClient venueclient.py:347 DEBUG connect to bridge
05/15/07 16:54:17 7736 VenueClient venueclient.py:351 DEBUG exiting loadbridges
05/15/07 16:54:17 7736 VenueClientController venueclientcontroller.py:1624 DEBUG There is no personal venues file to load.
Loaded C:\Documents and Settings\liugq\Application Data\AccessGrid3\Config\PluginDatabase
Loaded E:\eclipse-project\AccessGrid\Config\PluginDatabase
05/15/07 16:54:21 7736 NodeService agnodeservice.py:290 INFO NodeService.SetServiceEnabledByMediaType
05/15/07 16:54:21 7736 NodeService agnodeservice.py:257 INFO NodeService.GetServices
05/15/07 16:54:21 7736 NodeService agnodeservice.py:265 ERROR Exception in AGNodeService.GetServices.
File "E:\eclipse-project\AccessGrid\AccessGrid\AGNodeService.py", line 261, in GetServices
serviceSubset = AGServiceManagerIW(
File "E:\eclipse-project\AccessGrid\AccessGrid\interfaces\AGServiceManager_client.py", line 106, in GetServices
request = GetServicesRequest()
NameError: global name 'GetServicesRequest' is not defined
05/15/07 16:54:21 7736 VenueClient venueclient.py:1839 ERROR VenueClient.SetAudioEnabled: Error enabling audio
File "E:\eclipse-project\AccessGrid\AccessGrid\VenueClient.py", line 1837, in SetAudioEnabled
self.nodeService.SetServiceEnabledByMediaType("audio",enableFlag)
File "E:\eclipse-project\AccessGrid\AccessGrid\AGNodeService.py", line 291, in SetServiceEnabledByMediaType
serviceList = self.GetServices()
File "E:\eclipse-project\AccessGrid\AccessGrid\AGNodeService.py", line 266, in GetServices
raise Exception("AGNodeService.GetServices failed: %s" \
Exception: AGNodeService.GetServices failed: global name 'GetServicesRequest' is not defined
05/15/07 16:54:21 7736 VenueClient venueclient.py:1811 INFO Error enabling video
05/15/07 16:54:21 7736 VenueClient venueclient.py:1832 ERROR Error enabling video
File "E:\eclipse-project\AccessGrid\AccessGrid\VenueClient.py", line 1819, in SetVideoEnabled
serviceList = self.nodeService.GetServices()
05/15/07 16:54:21 7736 NodeService agnodeservice.py:638 INFO NodeService.GetConfigurations
05/15/07 16:54:21 7736 CertificateManager certificatemanager.py:212 DEBUG Opened repository C:\Documents and Settings\liugq\Application Data\AccessGrid3\Config\certRepo
05/15/07 16:54:21 7736 Toolkit toolkit.py:469 INFO Initialized certificate manager.
When it runs to _ptr(BIO.py:32],the Eclipse prompts: "The python.exe has problems...."
The stack info is:
VenueClient.py
MainThread
_ptr [BIO.py:32]
load_cert_bio [X509.py:494]
load_cert [X509.py:490]
__init__ [CertificateRepository.py:1422]
_GetCertificates [CertificateRepository.py:1145]
FindCertificates [CertificateRepository.py:1187]
FindCertificatesWithMetadata [CertificateRepository.py:1198]
GetCACerts [CertificateManager.py:763]
_InitializeCADir [CertificateManager.py:640]
InitEnvironment [CertificateManager.py:559]
GetCertificateManager [Toolkit.py:470]
__SetMenubar [VenueClientUI.py:520]
__BuildUI [VenueClientUI.py:968]
__init__ [VenueClientUI.py:235]
main [VenueClient.py:136]
? [VenueClient.py:158]
run [pydevd.py:548]
? [pydevd.py:697]
SOAP Server
Thread-7
Thanks.
liugq
2007-05-15
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20070515/e3daa0ca/attachment.htm>
