[AG-TECH] bridge not in central registry
Kaizaad Bilimorya
kaizaad at sharcnet.ca
Thu Mar 29 20:44:21 CDT 2007
Hello,
We are running a bridge server that seems to drop out from the central
registry http://www.accessgrid.org/registry/peers.txt
Physically, the bridge doesn't seem to loose network connectivity, but
when a client starts up and gets the list of bridges, sometimes our bridge
is not there. After waiting a few minutes and then restarting the client,
the bridge shows up in the list:
Bridge Host Port Type Status Distance PortRange
SHARCNET agbs.sharcnet.ca 20000 QuickBridge Enabled 0.0160 50000-50200
I can actually just run the "RegistryClient.py" command (from the bridge
itself) and sometimes I see it listed but then on the next run it is gone.
name: SHARCNET host: agbs.sharcnet.ca port: 20000 dist:0.0015721321106
name: UofC host: bullet.uchicago.edu port: 20200 dist:0.0685670375824
name: Argonne host: milton.mcs.anl.gov port: 8030 dist:0.0720429420471
name: WestGrid host: venueserver2.westgrid.ca port: 20000 dist:0.172122955322
name: NIEeS host: agiraffe.niees.group.cam.ac.uk port: 29999 dist:0.353329181671
name: AGSC host: sam.ag.manchester.ac.uk port: 1992 dist:0.359209060669
name: onlyfinland host: vy216.ucs.fi port: 20000 dist:0.452105998993
name: APAG host: vv3.ap-accessgrid.org port: 20000 dist:0.751379966736
name: JCU host: hpc-external.jcu.edu.au port: 20000 dist:0.772580862045
name: Sheridan host: oa-ag3-venue.sheridanc.on.ca port: 20000 dist:8.37
I think it is dropping out of the registry because I would expect it to be
first in the list since it is the closest. Even when I increase the
"LookupBridge(self, maxToReturn=20):" it still is not listed some of the
time.
Any insight would be helpful
thanks
-k
