[AG-TECH] Sony EVI-HD1 camera
    Ladan Gharai
    ladan at isi.edu
    Fri Mar  9 11:53:47 CST 2007
Hi John,
On Mar 9, 2007, at 10:07 AM, John I Quebedeaux Jr wrote:
> Well, that camera does specify the type of output that Ultragrid
> works with on that HD-SDI connection (SMPTE-292M output)... i
> suspect then the details get down to the hardware on the computer
> side and networking, etc. It has other outputs, but not IEE1394
> (firewire) which is where most HD cameras do onboard mpeg2 encoding/
> lag that Brian spoke of. I'm... guessing? that HD-SDI is uncompressed.
   correct, HD-SDI is the uncompressed HDTV format. And there are a
number of HDTV capture cards on the market with HD-SDI input/output.
The Centaurus card from www.dvs.de  is the capture card the UltraGrid
system currently supports.
  HDTV cameras with IEEE1394 output, provide an MPEG2 compressed HDTV
stream.
  HDMI capture card/cameras becoming available is very interesting
and I'd be very interested to see how they compare in performance
with HD-SDI systems.
> My concerns in meetings get back to having an "environment" of
> human presence @ multiple sites that can interface naturally -
> which includes video sources from the front and back of the room
> (what I call "environmental feedback") - typically called the
> "presenter camera" in the back of an AG room. I can possibly see
> having an HD camera in the front and back of the room to do this...
> then maybe another for... i've always felt you can't have enough
> cameras!
> -John Q.
> John I. Quebedeaux, Jr.; Louisiana State University
> Computer Manager LBRN; 131 Life Sciences Bldg.
> e-mail: johnq at lsu.edu; web: http://lbrn.lsu.edu
> phone: 225-578-0062 / fax: 225-578-2597
> On Mar 8, 2007, at 4:11 PM, Colin Perkins wrote:
>> We've done some work with uncompressed HD conferencing which might
>> be relevant: http://ultragrid.east.isi.edu/
>> Colin
>> On 8 Mar 2007, at 21:14, Brian Corrie wrote:
>>> Hi John,
>>> Interesting... Does anyone know anything about SDI HD capture
>>> cards. We are looking at HD as well (but no direct experience
>>> yet) and the trick seems to be to get video off of the camera
>>> avoiding the onboard encoding of the video, which often adds
>>> significant latency (which is not good for AG of course). Does
>>> anyone know if the SDI out of this camera either has onboard
>>> hardware encoding (so low latency) and/or whether the SDI out is
>>> uncompressed video (I don't know anything about SDI other than
>>> that it is a broadcast oriented standard). Since this is a video
>>> conferencing camera one would assume the SDI is raw video (it
>>> looks like it base on my reading). So once one gets it out of the
>>> camera how does one get it to the computer... There must be an HD
>>> SDI capture card available.
>>> We are looking at the Sony HDR-HC7 prosumer HD camcorder as a
>>> possibility. They aren't available yet, but any day now... They
>>> have HDMI out, which is uncompressed video. There is a HDMI
>>> capture card that can handle raw uncompressed HD video at 1080i
>>> available from Black Magic that looks promising... The camera is
>>> around $1500 and the card is $250.
>>> http://www.blackmagic-design.com/products/intensity/
>>> We are going to be purchasing this pair as soon as the camera is
>>> available, so I will let everyone know how this works out. If it
>>> does work its a pretty inexpensive HD solution!
>>> Cheers,
>>> Brian
>>>> Someone asked me about this camera for HD use on the AG: http://
>>>> www.picturephone.com/products/sony_evi_hd1.htm
>>>> Anyone have any experience with it? I'm wondering if it was
>>>> used, how to best "capture" it into a system for use on the
>>>> AG... interest in using HD is high here. I'm more concerned
>>>> about logistical issues with high resolution images on displays
>>>> that don't have that much "resolution" space - particularly if
>>>> several sites are involved.
>>>> -John Q.
>> Colin Perkins
>> http://csperkins.org/
