[AG-TECH] building rat for AG3 on ubuntu edgy
    Brad Langhorst
    brad at langhorst.com
    Wed Mar  7 17:02:20 CST 2007
I'm having trouble building AG...
using the instructions at
http://www-new.mcs.anl.gov/fl/research/accessgrid/software/cvs-instructions.html
is that the right set of instructions?
I can build many of the ag-media components but not rat
gcc -g -O2 -W -Wall -Wwrite-strings -Wbad-function-cast
-Wmissing-prototypes -Wcast-qual -Wmissing-declarations -Werror
-DHAVE_CONFIG_H  -c rtp.c
cc1: warnings being treated as errors
rtp.c: In function ‘rtp_recv_data’:
rtp.c:1365: warning: pointer targets in passing argument 2 of ‘udp_recv’
differ in signedness
rtp.c:1394: warning: pointer targets in assignment differ in signedness
rtp.c: In function ‘rtp_recv’:
rtp.c:1885: warning: pointer targets in passing argument 2 of ‘udp_recv’
rtp.c: In function ‘rtp_send_data’:
rtp.c:2201: warning: pointer targets in assignment differ in signedness
rtp.c:2245: warning: pointer targets in passing argument 2 of ‘udp_send’
rtp.c: In function ‘rtp_send_data_iov’:
rtp.c:2286: warning: pointer targets in assignment differ in signedness
rtp.c: In function ‘send_rtcp’:
rtp.c:2680: warning: pointer targets in passing argument 2 of ‘udp_send’
rtp.c: In function ‘rtp_send_bye_now’:
rtp.c:2868: warning: pointer targets in passing argument 2 of ‘udp_send’
rtp.c: In function ‘rtp_send_bye’:
rtp.c:2931: warning: pointer targets in passing argument 2 of ‘udp_recv’
rtp.c: In function ‘des_encrypt’:
rtp.c:3156: warning: pointer targets in passing argument 1 of ‘qfDES’
rtp.c: In function ‘des_decrypt’:
rtp.c:3164: warning: pointer targets in passing argument 1 of ‘qfDES’
make: *** [rtp.o] Error 1
bwlang at upup:/usr/src/ag-media/common/src$ gcc -v
Using built-in specs.
Target: i486-linux-gnu
Configured with: ../src/configure -v --enable-languages=c,c
++,fortran,objc,obj-c++,treelang --prefix=/usr --enable-shared
--with-system-zlib --libexecdir=/usr/lib --without-included-gettext
--enable-threads=posix --enable-nls --program-suffix=-4.1
--enable-__cxa_atexit --enable-clocale=gnu --enable-libstdcxx-debug
--enable-mpfr --enable-checking=release i486-linux-gnu
Thread model: posix
gcc version 4.1.2 20060928 (prerelease) (Ubuntu 4.1.1-13ubuntu5)
I could not find any archives to search ... I hope this is not a common
problem.
Should I just turn off the warnings?
brad
