[AG-TECH] Access Grid 3.1 beta1 Release Available
Andrew Rowley
Andrew.Rowley at manchester.ac.uk
Fri Jul 6 02:46:03 CDT 2007
This would be a correct solution, but I thought that changing all of the services may be the long way around. The fix I submitted checks that the executable has the inverted commas and adds them if it doesn't. Same result though...
Andrew :)
Access Grid Support Centre,
RSS Group,
Manchester Computing,
Kilburn Building,
University of Manchester,
Oxford Road,
Manchester,
M13 9PL,
UK
Tel: +44(0)161-275 0685
Email: Andrew.Rowley at manchester.ac.uk
-----Original Message-----
From: owner-ag-tech at mcs.anl.gov [mailto:owner-ag-tech at mcs.anl.gov] On Behalf Of Terry.Rankine at csiro.au
Sent: 06 July 2007 03:27
To: turam at mcs.anl.gov; Andrew.Rowley at manchester.ac.uk
Cc: ag-tech at mcs.anl.gov
Subject: RE: [AG-TECH] Access Grid 3.1 beta1 Release Available
Hi guys
is this related to my error and patch fix I sent through recently?
look for AG3.0.2 windows not working and then I replied to myself with
the fix.
You are assuming that the path passed to the windows "run this" has no
spaces - this is a bad assumption, and you should just pass it with
quotes on the executable paths. Both operation systems (Linux/windows)
will support paths in quotes.
here is the summary again.....
The error relates directly to launching a process with a space in the
path.
The fix is quite simple - when you build the paths for vic and rat it
the "Application Data\AccessGrid3\local_services\VideoProducerService"
path - use quotes.
So for vic in videoconsumerservice.py
self.executable = '"%s"' %os.path.join(os.getcwd(),vic)
And likewise for rat in audioservice.py
self.executable = '"%s"' % os.path.join(os.getcwd(), rat)
self.rat_media = '"%s"' % os.path.join(os.getcwd(), ratmedia)
self.rat_ui = '"%s"' % os.path.join(os.getcwd(), ratui)
Behalf Of Thomas D. Uram
Sent: Thursday, 5 July 2007 2:51 AM
To: Andrew.Rowley at manchester.ac.uk
Cc: ag-tech
Subject: Re: [AG-TECH] Access Grid 3.1 beta1 Release Available
I've been unable to reproduce this problem, but would be happy to apply
a patch and have you (and others) test it for inclusion in the final 3.1
release.
Tom
On 7/4/07 5:59 AM, Andrew A Rowley wrote:
I am still getting the same issue with this that I was having
with all versions since 3. The audio and video services do not start
when I enter a venue. Attached are my log files of the services. I
believe that the problem is to do with the fact that there are spaces in
the path to the executable (at least if I put the executable in inverted
commas, it goes away). This does not appear to affect everyone, but I
have seen it happen on systems other than mine, so I don't think this is
an isolated issue.
Andrew :)
RSS Group,
Kilburn Building,
Oxford Road,
Manchester,
M13 9PL,
UK
Sent: 29 June 2007 21:45
To: ag-tech
Subject: [AG-TECH] Access Grid 3.1 beta1 Release
Available
The Access Grid 3.1 beta1 software is available for
download at:
http://www.mcs.anl.gov/fl/research/accessgrid/software/releases/3.1-beta
1
This beta release includes new functionality and
numerous bug fixes.
3.1 (beta1) Changes
* Inclusion of media tools from Sumover project
* Venue Client startup time significantly reduced
* Improved bridging support
o VenueClient displays full list of bridges
(instead of limiting
list to ten)
o Maintains bridge cache in the background
o User preferences for whether and how often to
order bridges by
proximity; for refreshing the bridge cache
manually; and, for
user-specified bridge ordering
o Support for multiple bridge registries
* Supports organization of Venue data into folders
o Users can create folders for organizing Venue
data
* Displays timestamps in Jabber chat
* Support for SharedPresentation on Mac
* Support for user-specified multicast group for
multicast connectivity
detection
* Certificate-based Venue access control
o Includes required client-side proxy
certificate support
* Plugin support
o New extensibility mechanism allows integration
of client-side
applications
For full information on this release, and a complete
listing
of the bugs fixed, see the official release page (url
above).
As always, user feedback is welcome. Please file feature
requests,
bug reports, and enhancement requests via the Access
Grid Bugzilla
page at http://bugzilla.mcs.anl.gov/accessgrid.
Thanks to everyone involved for their hard work.
The AG Developers
07/04/07 11:52:47 5844 Toolkit config.py:609 DEBUG
System hostname of rosie.mvc.mcc.ac.uk is valid
07/04/07 11:52:47 5844 Toolkit toolkit.py:116 DEBUG
Initializing AG Toolkit version 3.1 beta1
07/04/07 11:52:47 5844 Toolkit toolkit.py:117 INFO
Command and arguments: ['C:\\Documents and
Settings\\zzalsar4\\Application
Data\\AccessGrid3\\local_services\\VideoConsumerService\\VideoConsumerSe
rvice.py', '--port', '63020', '--serviceManagerUri',
'http://rosie.mvc.mcc.ac.uk:11000/ServiceManager', '--token',
'8258014916440e7c6fd5284599e7fb67']
07/04/07 11:52:47 5844 VenueClient
preferences.py:188 DEBUG Preferences.LoadPreferences: open file
07/04/07 11:52:47 5844 Toolkit toolkit.py:166 INFO
Logfile Name: VideoConsumerService.log
07/04/07 11:52:47 5844 Toolkit toolkit.py:691 INFO
Service init: have profile None
07/04/07 11:52:47 5844 Toolkit toolkit.py:716 INFO
Service Initialization Complete.
07/04/07 11:52:47 5844 Toolkit agservice.py:393 INFO
Starting Service URI:
http://rosie.mvc.mcc.ac.uk:63020/Services/VideoConsumerService.825801490
74c0e7c702121dc9919d911
07/04/07 11:52:47 5844 Toolkit agservice.py:403
DEBUG Registering with service manager;
url=http://rosie.mvc.mcc.ac.uk:11000/ServiceManager
07/04/07 11:52:47 4316 Toolkit
videoconsumerservice.py:220 INFO SetIdentity: Andrew Rowley
07/04/07 11:52:47 4072 Toolkit agservice.py:285
DEBUG GetDescription:Capability in Service consumer, video,
82580149074c0e7c7013015aa80e5632, H261, 90000, 1, None, None
07/04/07 11:52:48 396 Toolkit agservice.py:239 INFO
AGService.SetEnabled : enabled = 1
07/04/07 11:53:26 4164 Toolkit agservice.py:183 INFO
SetStream: [producer, video, 7f00000206350e73db316f5eab787b21, H261,
90000, 1, None, None] 224.2.238.112 57306
07/04/07 11:53:26 4164 Toolkit agservice.py:197 INFO
SetStream: new configuration, set everything new!
07/04/07 11:53:26 4164 Toolkit agservice.py:210
DEBUG StreamDescription okay, assign it to service!
videoconsumerservice.py:126 INFO Setting processor affinity to all
processors
07/04/07 11:53:26 4164 Toolkit config.py:575 INFO
Found 2 processors; setting affinity
videoconsumerservice.py:183 INFO Starting VideoConsumerService
videoconsumerservice.py:184 INFO executable = C:\Documents and
Settings\zzalsar4\Application
Data\AccessGrid3\local_services\VideoConsumerService\vic.exe
videoconsumerservice.py:185 INFO options = ['-C', u'AGSC Venue Server
Lobby', '-t', '127', u'-XrtpName=Andrew Rowley',
u'-XrtpEmail=Andrew.Rowley at manchester.ac.uk', '-XrecvOnly=1',
'-XsiteDropTime=5', '-Xgeometry=500x500', '-Xtile=2',
u'224.2.238.112/57306']
07/04/07 11:53:26 4164 ProcessManager
processmanager.py:62 DEBUG Creating process: C:\Documents and
Data\AccessGrid3\local_services\VideoConsumerService\vic.exe -C "AGSC
Venue Server Lobby" -t 127 "-XrtpName=Andrew Rowley"
-XrtpEmail=Andrew.Rowley at manchester.ac.uk -XrecvOnly=1 -XsiteDropTime=5
-Xgeometry=500x500 -Xtile=2 224.2.238.112/57306
processmanager.py:100 ERROR process creation failed: (193,
'CreateProcess', '%1 is not a valid Win32 application.')
Traceback (most recent call last):
File
"C:\Python24\lib\site-packages\AccessGrid3\AccessGrid\Platform\win32\Pro
cessManager.py", line 73, in StartProcess
startup_info)
error: (193, 'CreateProcess', '%1 is not a valid Win32
application.')
07/04/07 11:54:00 4588 Toolkit agservice.py:263 INFO
Shut service down
07/04/07 11:52:46 4320 Toolkit config.py:609 DEBUG
07/04/07 11:52:46 4320 Toolkit toolkit.py:116 DEBUG
07/04/07 11:52:46 4320 Toolkit toolkit.py:117 INFO
Data\\AccessGrid3\\local_services\\AudioService\\AudioService.py',
'--port', '58691', '--serviceManagerUri',
'8258014916440e7c6f730f8546df3872']
07/04/07 11:52:46 4320 VenueClient
07/04/07 11:52:46 4320 Toolkit toolkit.py:166 INFO
Logfile Name: AudioService.log
07/04/07 11:52:46 4320 Toolkit toolkit.py:691 INFO
07/04/07 11:52:46 4320 Toolkit toolkit.py:716 INFO
07/04/07 11:52:46 4320 Toolkit agservice.py:393 INFO
http://rosie.mvc.mcc.ac.uk:58691/Services/AudioService.825801490a1c0e7c6
fc03aec82bdf4b5
07/04/07 11:52:46 4320 Toolkit agservice.py:403
07/04/07 11:52:46 4228 Toolkit agservice.py:166 INFO
SetConfiguration: Unrecognized parameter ignored: Force AC97
07/04/07 11:52:46 4228 Toolkit audioservice.py:349
INFO SetIdentity: Andrew Rowley Andrew.Rowley at manchester.ac.uk
07/04/07 11:52:46 5268 Toolkit agservice.py:285
DEBUG GetDescription:Capability in Service consumer, audio,
825801490a1c0e7c6fb20168de822308, L16, 16000, 1, None, None
825801490a1c0e7c6fb20168de822308, L16, 8000, 1, None, None
825801490a1c0e7c6fb20168de822308, L8, 16000, 1, None, None
825801490a1c0e7c6fb20168de822308, L8, 8000, 1, None, None
825801490a1c0e7c6fb20168de822308, PCMU, 16000, 1, None, None
825801490a1c0e7c6fb20168de822308, PCMU, 8000, 1, None, None
825801490a1c0e7c6fb20168de822308, GSM, 16000, 1, None, None
825801490a1c0e7c6fb20168de822308, GSM, 8000, 1, None, None
DEBUG GetDescription:Capability in Service producer, audio,
07/04/07 11:52:48 5224 Toolkit agservice.py:239 INFO
07/04/07 11:53:25 5120 Toolkit agservice.py:183 INFO
SetStream: [consumer, audio, 825801490a1c0e7c6fb20168de822308, L16,
16000, 1, None, None, consumer, audio, 825801490a1c0e7c6fb20168de822308,
L16, 8000, 1, None, None, consumer, audio,
825801490a1c0e7c6fb20168de822308, L8, 16000, 1, None, None, consumer,
audio, 825801490a1c0e7c6fb20168de822308, L8, 8000, 1, None, None,
consumer, audio, 825801490a1c0e7c6fb20168de822308, PCMU, 16000, 1, None,
None, consumer, audio, 825801490a1c0e7c6fb20168de822308, PCMU, 8000, 1,
None, None, consumer, audio, 825801490a1c0e7c6fb20168de822308, GSM,
GSM, 8000, 1, None, None, producer, audio,
825801490a1c0e7c6fb20168de822308, L16, 16000, 1, None, None]
224.2.240.144 63466
07/04/07 11:53:25 5120 Toolkit agservice.py:197 INFO
07/04/07 11:53:25 5120 Toolkit agservice.py:210
07/04/07 11:53:25 5120 Toolkit audioservice.py:292
INFO Stop service
07/04/07 11:53:25 5120 Toolkit audioservice.py:303
INFO Executing rat-kill
07/04/07 11:53:25 5120 ProcessManager
processmanager.py:62 DEBUG Creating process: .\rat-kill.exe
processmanager.py:75 DEBUG Create process returns: (<PyHANDLE:772>,
<PyHANDLE:776>, 4100, 4164)
07/04/07 11:53:26 5120 ProcessManager
processmanager.py:138 ERROR couldn't shutdown process <PyHANDLE:772>:
(1444, 'PostThreadMessage', 'Invalid thread identifier.')
File
cessManager.py", line 131, in TerminateProcess
win32api.PostThreadMessage(self.threadid[pid], 18,
0, 0)
error: (1444, 'PostThreadMessage', 'Invalid thread
identifier.')
processmanager.py:145 ERROR couldn't terminate process <PyHANDLE:772>:
(5, 'TerminateProcess', 'Access is denied.')
File
cessManager.py", line 142, in TerminateProcess
win32process.TerminateProcess(pid, 0)
error: (5, 'TerminateProcess', 'Access is denied.')
07/04/07 11:53:26 5120 Toolkit audioservice.py:277
INFO Starting AudioService
07/04/07 11:53:26 5120 Toolkit audioservice.py:278
INFO executable = C:\Documents and Settings\zzalsar4\Application
Data\AccessGrid3\local_services\AudioService\rat.exe
07/04/07 11:53:26 5120 Toolkit audioservice.py:280
INFO options = ['-C', u'AGSC Venue Server Lobby', '-S',
u'8258014916e03315ba54cd300bfe16d9', '-f', 'L16-16K-Mono', '-t', '127',
u'224.2.240.144/63466']
Data\AccessGrid3\local_services\AudioService\rat.exe -C "AGSC Venue
Server Lobby" -S 8258014916e03315ba54cd300bfe16d9 -f L16-16K-Mono -t 127
224.2.240.144/63466
File
startup_info)
application.')
07/04/07 11:53:26 4608 Toolkit agservice.py:239 INFO
AGService.SetEnabled : enabled = 0
07/04/07 11:53:26 4608 Toolkit agservice.py:245 INFO
Stopping service
07/04/07 11:53:26 4608 Toolkit audioservice.py:292
INFO Stop service
07/04/07 11:53:26 4608 Toolkit audioservice.py:303
07/04/07 11:53:26 4608 ProcessManager
processmanager.py:75 DEBUG Create process returns: (<PyHANDLE:748>,
<PyHANDLE:772>, 5288, 5644)
processmanager.py:138 ERROR couldn't shutdown process <PyHANDLE:748>:
File
0, 0)
identifier.')
processmanager.py:145 ERROR couldn't terminate process <PyHANDLE:748>:
File
07/04/07 11:53:29 5644 Toolkit agservice.py:183 INFO
224.2.240.144 63466
07/04/07 11:53:29 5644 Toolkit agservice.py:194 INFO
SetStream: ignoring trivial re-configuration
07/04/07 11:53:29 3284 Toolkit agservice.py:239 INFO
07/04/07 11:53:29 3284 Toolkit agservice.py:248 INFO
Starting service
07/04/07 11:53:29 3284 Toolkit audioservice.py:277
07/04/07 11:53:29 3284 Toolkit audioservice.py:278
07/04/07 11:53:29 3284 Toolkit audioservice.py:280
07/04/07 11:53:29 3284 ProcessManager
224.2.240.144/63466
File
startup_info)
application.')
07/04/07 11:53:58 2980 Toolkit audioservice.py:292
INFO Stop service
07/04/07 11:53:58 2980 Toolkit audioservice.py:303
07/04/07 11:53:58 2980 ProcessManager
processmanager.py:75 DEBUG Create process returns: (<PyHANDLE:752>,
<PyHANDLE:744>, 4448, 5796)
07/04/07 11:53:59 2980 ProcessManager
processmanager.py:138 ERROR couldn't shutdown process <PyHANDLE:752>:
File
0, 0)
identifier.')
processmanager.py:145 ERROR couldn't terminate process <PyHANDLE:752>:
File
07/04/07 11:53:59 888 Toolkit agservice.py:263 INFO
Shut service down
07/04/07 11:53:59 888 Toolkit audioservice.py:292
INFO Stop service
07/04/07 11:53:59 888 Toolkit audioservice.py:303
07/04/07 11:53:59 888 ProcessManager
processmanager.py:75 DEBUG Create process returns: (<PyHANDLE:740>,
<PyHANDLE:776>, 1760, 3248)
processmanager.py:138 ERROR couldn't shutdown process <PyHANDLE:740>:
File
0, 0)
identifier.')
processmanager.py:145 ERROR couldn't terminate process <PyHANDLE:740>:
File
