[AG-TECH] Access Grid 3.1 beta1 Release Available
Antonio Bandeira
bandeira at fe.up.pt
Wed Jul 4 08:16:14 CDT 2007
Try something like "C:\PROGRA~1\" instead of "C:\Program Files\". It usually
helps in case of problems concerning with spaces in the path and old
parsers.
Since MSDOS names should have only 8 chars long, at maximum, and no spaces
or special chars. So, if you have a directory with more than 8 chars, you
can use an abbreviation of it using the first 6 and adding '~1' at the end.
If you have more than one directory starting with the same first 6 chars,
'~2' and '~3' can be used.
I believe that this notation can also be used for file names.
Best regards,
António Bandeira
FEUP :: SICC ~ uTICM
+351 225 574 199 (ext.3535)
-----Original Message-----
From: owner-ag-tech at mcs.anl.gov [mailto:owner-ag-tech at mcs.anl.gov] On Behalf
Of Andrew A Rowley
Sent: 04 July 2007 12:00
To: Thomas D. Uram; ag-tech
Subject: RE: [AG-TECH] Access Grid 3.1 beta1 Release Available
I am still getting the same issue with this that I was having with all
versions since 3. The audio and video services do not start when I enter a
venue. Attached are my log files of the services. I believe that the
problem is to do with the fact that there are spaces in the path to the
executable (at least if I put the executable in inverted commas, it goes
away). This does not appear to affect everyone, but I have seen it happen
on systems other than mine, so I don't think this is an isolated issue.
Andrew :)
Access Grid Support Centre,
RSS Group,
Manchester Computing,
Kilburn Building,
University of Manchester,
Oxford Road,
Manchester,
M13 9PL,
UK
Tel: +44(0)161-275 0685
Email: Andrew.Rowley at manchester.ac.uk
> Behalf Of Thomas D. Uram
> Sent: 29 June 2007 21:45
> To: ag-tech
> Subject: [AG-TECH] Access Grid 3.1 beta1 Release Available
> The Access Grid 3.1 beta1 software is available for download at:
> http://www.mcs.anl.gov/fl/research/accessgrid/software/releases/3.1-be
> ta1
> This beta release includes new functionality and numerous bug fixes.
> 3.1 (beta1) Changes
> * Inclusion of media tools from Sumover project
> * Venue Client startup time significantly reduced
> * Improved bridging support
> o VenueClient displays full list of bridges (instead of limiting
> list to ten)
> o Maintains bridge cache in the background
> o User preferences for whether and how often to order bridges by
> proximity; for refreshing the bridge cache manually; and, for
> user-specified bridge ordering
> o Support for multiple bridge registries
> * Supports organization of Venue data into folders
> o Users can create folders for organizing Venue data
> * Displays timestamps in Jabber chat
> * Support for SharedPresentation on Mac
> * Support for user-specified multicast group for multicast connectivity
> detection
> * Certificate-based Venue access control
> o Includes required client-side proxy certificate support
> * Plugin support
> o New extensibility mechanism allows integration of client-side
> applications
> For full information on this release, and a complete listing of the
> bugs fixed, see the official release page (url above).
> As always, user feedback is welcome. Please file feature requests, bug
> reports, and enhancement requests via the Access Grid Bugzilla page at
> http://bugzilla.mcs.anl.gov/accessgrid.
> Thanks to everyone involved for their hard work.
> The AG Developers
