[AG-TECH] RE: [AG-DEV] Problem of running ‘r_3_0_2_final’ source code downloaded from CVS.
박종민
alrogi at icu.ac.kr
Wed Jan 17 12:28:59 CST 2007
Hello.
Thank you for your e-mail.
I can solve the error message with wsdl2py and wsdl2dispatch.
However, I cannot run ‘r_3_0_2_final’ source code downloaded from CVS.
I cannot install all dependencies of your mentioned webpage.
For example, there are several programs as follows.
Zope Interface (3.01+)
Python interface module used by Twisted (not used directly by the Access
Grid source)
http://www.zope.org/Products/ZopeInterface
common (FuturesLab CVS)
Argonne's copy of UCL's common library
CVSROOT=:pserver:anonymous at cvs.mcsanl.gov:/cvs/fl
module: common
cd common; make
cd examples/_common
python setup.py build
python setup.py install
Apple Bonjour
Already installed on OSX; needed for Windows and Linux. Note that some of
the current Linux packages currently rely on Avahi instead; in that case,
neither Apple's Bonjour nor the Python Bonjour module below are required.
http://www.apple.com/macosx/features/bonjour
Bonjour Python module (FuturesLab CVS)
Python interface to Apple's Bonjour
CVSROOT=:pserver:anonymous at cvs.mcs.anl.gov:/cvs/fl
module: bonjour
cd bonjour
OpenSSL (0.9.8)
Network security library. The 0.9.8 release includes support for
manipulating proxy certificates, so the current CVS requires it.
http://www.openssl.org
I want to make the development version of the Access Grid 3.0.2 Toolkit for
Windows.
However, because my developing platform is Windows XP, I couldn’t install
some of the dependency programs such as ‘common (FuturesLab CVS)’.
I think ‘common (FuturesLab CVS)’ is a program for platform like LINUX
because of ‘make’.
I wonder whether
1) I can do all the process for my development only in Windows
platform
Or 2) I should use some results obtained from the other platform (like
linux)
Or 3) I should do all the process for my development only some other
platform (like linux)
Please let me know the answer about above question,
And give me some advice for that case.
Jongmin Park
-----Original Message-----
From: Michael Braitmaier [mailto:braitmaier at hlrs.de]
Sent: Wednesday, January 17, 2007 5:13 PM
To: 박종민
Cc: 'ag-dev'; ag-tech at mcs.anl.gov; ag-users at mcs.anl.gov
Subject: Re: [AG-DEV] Problem of running ‘r_3_0_2_final’ source code
Hello!
Please make sure you have all dependencies installed as listed on the
following webpage's section on Dependencies:
http://www-new.mcs.anl.gov/fl/research/accessgrid/software/cvs.html
Furthermore the error message with wsdl2py and wsdl2dispatch is caused
by the fact that these files are in your scripts' install directory as
wsdl2py and wsdl2dispatch (notice the missing file extension). So one
easy easy way would be renaming or linking them to wsdl2py.py and
wsdl2dispatch.py to allow the CvsSetup.py script to find them.
However there might be a better solution for this, this is the way I
have done it so far.
Michael
박종민 schrieb:
> Hello. I worked to modify Access Grid 3.0.2 Toolkit.
> Although I performed the method of ‘README-developers’ file in folders
> downloaded from CVS,
> I cannot run Access Grid 3.0.2 source code.
> I installed .NET 2003 for ‘devenv.exe’. And then I use Windows XP
> platform.
> I ran command as follows.
> E:\AGTk>python AccessGrid/tools/CvsSetup.py --agdir AccessGrid
> Error message is like this.
> Creating file E:\AGTk\AccessGrid\Config\nodeConfig\defaultWindows from
> Acces
> sGrid\packaging\config\defaultWindows
> Generating Interfaces
> C:\Python23\python.exe: can't open file 'C:\Python23\Scripts\wsdl2py.py'
> 'C:\Python23\Scripts\wsdl2dispatch.py'
> To use this configuration:
> Make sure media-related programs (vic, rat, etc.) are in your path.
> On Windows: copying the vic and rat related binaries (if needed,
> from a real install) into their own directory before adding them
> to your path is recommended. If you don't want to bother modifying
> your path, copying them into AccessGrid/bin is a quick fix.
> set AGTK_LOCATION to E:\AGTk\AccessGrid
> set PYTHONPATH to E:\AGTk\AccessGrid
> Wrote win32 batchfile init to env-init.bat
> E:\AGTk>
> To solve this error, I tried to install ‘SOAPpy-0.12.0’. However, the
> error also is presented.
> E:\AGTk\SOAPpy-0.12.0>python setup.py install
> Traceback (most recent call last):
> File "setup.py", line 8, in ?
> from SOAPpy.version import __version__
> File "E:\AGTk\SOAPpy-0.12.0\SOAPpy\__init__.py", line 5, in ?
> from Client import *
> File "E:\AGTk\SOAPpy-0.12.0\SOAPpy\Client.py", line 57, in ?
> from Parser import parseSOAPRPC
> File "E:\AGTk\SOAPpy-0.12.0\SOAPpy\Parser.py", line 8, in ?
> import fpconst
> ImportError: No module named fpconst
> I think that this is because ‘fpconst.zip’ is not installed.
> In AccessGrid.org homepage
> (http://www-
unix.mcs.anl.gov/fl/research/accessgrid/software/developer.html),
> Because the hyperlink of ‘fpconst.zip’ is not operated, I cannot
> download this file.
> In conclusion, I want to run ‘r_3_0_2_final’ source code downloaded
> from CVS.
> If anyone who knows to solve this situation exists, please send email
> to me.
> Thank you for your reading.
> Regards,
> Jongmin Park
Dipl.-Inf. Michael Braitmaier
HLRS - Visualization / Video Conferencing
University of Stuttgart
Germany
Phone: ++49 711 685 65996
Fax : ++49 711 682 357
Website: http://www.hlrs.de/people/braitmaier/
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20070118/d87ed62e/attachment.htm>
