[AG-TECH] AGService development problem
Ismail Bhana
i.m.bhana at reading.ac.uk
Sat Jan 13 09:01:57 CST 2007
I've been developing a set of node services called JMast (JMastConsumer
and JMastProducer services) which basically provide a form of
application sharing using streaming technologies. However, whilst I can
get the software to boot from AG 3.0.2 with parameters passed correctly
I'm having a problem where I'm being passed the same multicast
address/port as the vic tool which causes vic to crash. If I change the
Capabilities type (say, from "JMAST" to "jmast1") a different address to
vic is assigned in the first instance of execution but the next time I
run the software its back to giving me the same address/port as vic and
I can't really work out why.
Posted below are the scripts I've been using, I'm a novice at this so
any comments/help would be greatly appreciated.
Ismail Bhana
# Name: JMastProducerService.py
# Author: IMB
# Created: 2007/01/01
# Copyright: (c) 2007
# Licence: See LICENSE.TXT
import os
import time
import agversion
agversion.select(3)
from AccessGrid import Toolkit
from AccessGrid.Descriptions import Capability
from AccessGrid.AGService import AGService
from AccessGrid.AGParameter import OptionSetParameter
class JMastProducerService( AGService ):
encodings = [ "jpeg/rtp" ]
quality = [ "Highest", "High", "Medium", "Low", "Lowest" ]
size = [ "None", "800x600", "600x400", "640x480", "480x300", "300x200" ]
def __init__( self ):
AGService.__init__( self )
self.capabilities = [ Capability(Capability.PRODUCER,
"JMAST",
"JPEG/RTP",
100000,
self.id) ]
self.executable = os.path.join(os.getcwd(), "JMastProducer.exe")
# Set configuration parameters
self.encoding = OptionSetParameter("Stream Encoding",
"jpeg/rtp", JMastProducerService.encodings)
self.quality = OptionSetParameter("Stream Quality", "Medium",
JMastProducerService.quality)
self.size = OptionSetParameter("Max. Window Size", "None",
JMastProducerService.size)
self.configuration.append(self.encoding)
self.configuration.append(self.quality)
self.configuration.append(self.size)
self.profile = None
def Start(self):
self.log.debug("JMastProducerService.Start: Starting Service")
try:
options = []
if self.enabled:
self.log.debug('self.streamDescription: %s',
self.streamDescription)
options.append("-streamName")
options.append(self.streamDescription.name)
options.append("-streamType")
options.append(self.streamDescription.location.type)
options.append("-streamAddr")
options.append(self.streamDescription.location.host)
options.append("-streamPort")
options.append(self.streamDescription.location.port)
options.append("-streamTTL")
options.append(self.streamDescription.location.ttl)
options.append("-optionEncoding")
options.append(self.encoding.value)
options.append("-optionQuality")
options.append(self.quality.value)
options.append("-optionSize")
options.append(self.size.value)
self.log.debug(" executable = %s" % self.executable)
self.log.debug(" options = %s" % options)
self._Start(options)
except:
self.log.exception("Exception in JMastProducerService.Start")
raise Exception("Failed to start service")
def Stop(self):
self.log.debug("JMastProducerService.Stop: Stopping Service")
jmastKill = os.path.join(os.getcwd(), "KillProducer.exe")
self.processManager.StartProcess(jmastKill, [])
time.sleep(0.2)
AGService.ForceStop(self)
def SetStream(self, streamDescription):
self.log.debug('JMastProducerService.SetStream: %s',
streamDescription)
self.log.debug(' enabled: %d', self.enabled)
ret = AGService.ConfigureStream(self, streamDescription)
if ret and self.started:
# service is already running with this config; ignore
return
# if started, stop
if self.started:
self.Stop()
# if enabled, start
if self.enabled:
self.Start()
def SetIdentity(self, profile):
self.log.debug("JMastProducerService.SetIdentity: %s %s",
profile.name, profile.email)
self.profile = profile
if __name__ == "__main__":
from AccessGrid.interfaces.AGService_interface import AGService as
AGServiceI
from AccessGrid.AGService import RunService
service = JMastProducerService()
serviceI = AGServiceI(service)
RunService(service, serviceI)
# Name: JMastConsumerService.py
# Author: IMB
import os
import time
import agversion
agversion.select(3)
class JMastConsumerService( AGService ):
self.capabilities = [ Capability(Capability.CONSUMER,
"JMAST",
"JPEG/RTP",
100000,
self.id) ]
self.executable = os.path.join(os.getcwd(), "JMastConsumer.exe")
self.profile = None
def Start(self):
self.log.debug("JMastConsumer.Start: Starting Service")
try:
options = []
if self.enabled:
except:
self.log.exception("Exception in JMastConsumerService.Start")
def Stop(self):
self.log.debug("JMastConsumerService.Stop: Stopping Service")
jmastKill = os.path.join(os.getcwd(), "KillConsumer.exe")
time.sleep(0.2)
self.log.debug('JMastConsumerService.SetStream: %s',
streamDescription)
return
# if started, stop
if self.started:
self.Stop()
# if enabled, start
if self.enabled:
self.Start()
self.log.debug("JMastConsumerService.SetIdentity: %s %s",
AGServiceI
service = JMastConsumerService()
[ServiceDescription]
name = JMastProducerService
description = JMast Multicast Application Sharing Tool Producer
capabilities = Capability1
executable = JMastProducerService.py
platform = neutral
version = 0.1
[Capability1]
role = producer
type = JMAST
name = JMastConsumerService
description = JMast Multicast Application Sharing Tool Consumer
executable = JMastConsumerService.py
platform = neutral
version = 0.1
[Capability1]
role = consumer
type = JMAST
