[AG-TECH] win32 + correct vnc program
    Terry.Rankine at csiro.au
    Sun Feb 18 17:21:15 CST 2007
Hi all
I have tried a few VNC programs, and I cant seem to get them to work
with AG 3.0.2
According to a mate they need to take the -passwd or /passwd option to
take the encrypted password file from the venue client.
Can someone please help me set it up? Or point me to a web twiki howto.
Cheers.
Terry Rankine
tightVNC:
vncviewer /help
vncviewer [/8bit] [/shared] [/noshared] [/swapmouse]
      [/belldeiconify] [/listen [<port>]] [/fullscreen] [/restricted]
[/viewonly]
      [/emulate3] [/noemulate3] [/emulate3timeout <ms>] [/emulate3fuzz
<pixels>]
      [/notoolbar] [/scale <percentage>] [/config <filename>]
[/disableclipboard]
      [/encoding <encname>] [/compresslevel <n>] [/quality <n>]
      [/loglevel <n>] [/logfile <filename>] [/register]
      [/nocursor] [/dotcursor] [/smalldotcursor] [/normalcursor] [/help]
      [/nojpeg] [/nocursorshape] [/noremotecursor]
[<server>[:<display>]]
For full details, see the documentation.
realVNC 4.1.2
VNC Viewer Free Edition - VNC Viewer Free Edition for Win32, Version
4.1.2
Built on May 12 2006 at 14:47:32
Copyright (r) RealVNC Ltd. 2002-2005
usage: vncviewer <options> <hostname>[:<display>]
Command-line options:
  -help                                - Provide usage information.
  -config <file>                       - Load connection settings from
VNC Viewe
r 3.3 settings file
  -console                             - Run with a console window
visible.
  <setting>=<value>                    - Set the named configuration
parameter.
    (Parameter values specified on the command-line override those
specified by
other configuration methods.)
Log names:
  TcpSocket, EventManager, DynamicFn, RegConfig, MsgWindow,
DIBSectionBuffer, WM
Shatter, CPointer, Clipboard, DeviceContext, MonitorInfo,
LowLevelKeyEvents, Thr
eading, Registry, CKeyboard, AboutDialog, PropSheet, Dialog, SMsgWriter,
Cursor,
 PixelBuffer, CConnection, Config, main, Options, Info, DesktopWindow,
CConnThre
ad, CConn
Log destinations:
  file
  stdout
  stderr
Parameters:
Global Parameters:
  ZlibLevel  - Zlib compression level (default=-1)
  Log        - Specifies which log output should be directed to which
target
               logger, and the level of output to log. Format is
               <log>:<target>:<level>[, ...]. (default=*:stderr:0)
  Listen     - Accept incoming connections from VNC servers. (default=0)
  AutoReconnect - Offer to reconnect to the remote server if the
connectionis
               dropped because an error occurs. (default=1)
  MenuKey    - The key which brings up the popup menu (default=F8)
  Monitor    - The monitor to open the VNC Viewer window on, if
available.
               (default=)
  AcceptBell - Produce a system beep when requested to by the server.
               (default=1)
  Emulate3   - Emulate middle mouse button when left and right buttons
are used
               simulatenously. (default=0)
  PointerEventInterval - The interval to delay between sending one
pointer
               event and the next. (default=0)
  Protocol3.3 - Only use protocol version 3.3 (default=0)
  DisableWinKeys - Pass special Windows keys directly to the server.
               (default=1)
  ServerCutText - Accept clipboard changes from the server. (default=1)
  ClientCutText - Send clipboard changes to the server. (default=1)
  SendKeyEvents - Send key presses (and releases) to the server.
(default=1)
  SendPointerEvents - Send pointer (mouse) events to the server.
(default=1)
  Shared     - Allow existing connections to the server to
continue.(Default is
               to disconnect all other clients) (default=0)
  AutoSelect - Auto select pixel format and encoding (default=1)
  PreferredEncoding - Preferred graphical encoding to use - overridden
by
               AutoSelect if set. (ZRLE, Hextile or Raw) (default=ZRLE)
  FullScreen - Use the whole display to show the remote desktop.(Press
F8 to
               access the viewer menu) (default=0)
  LowColourLevel - Colour level to use on slow connections. 0 = Very Low
(8
               colours), 1 = Low (64 colours), 2 = Medium (256 colours)
               (default=1)
  FullColour - Use full colour (default is to use low colour unless auto
select
               decides the link is fast enough). (default=0)
  UseDesktopResize - Support dynamic desktop resizing (default=1)
  UseLocalCursor - Render the mouse cursor locally (default=1)
  DebugDelay - Milliseconds to display inverted pixel data - a debugging
               feature (default=0)
Press Enter/Return key to continue
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20070219/ac4044f8/attachment.htm>
