[AG-TECH] AG 3.0.2 & Windows Vista.
Mike Daley
Mike.W.Daley at cs.cardiff.ac.uk
Fri Feb 16 03:09:12 CST 2007
I copied dnssd.dll to windows/system32 directory and got over that
problem. Tom said that Bonjour is not strictly needed.
Mike
Derek Piper wrote:
> dnssd.dll is in the C:\Program Files\Bonjour folder by default
> (wherever Bonjour is installed to). It needs to be within the PATH of
> the any program that has something to do with networking in order for
> that program to work correctly. I wonder if DLLs have to be in certain
> 'blessed' locations in order to be loaded on Vista (I'm guessing).
> I hated the way it 'took over' things when I was testing things
> under XP - I had a problem with AGVCR not including the original
> system's PATH on its standalone runtime, which meant it would then
> fail when Bonjour was installed on the system.
> Derek
> PS: Bravo for trying it out, even if I think 'early adopter' is
> pronounced 'masochist' ;)
> Jimmy Miklavcic wrote:
>> The two things that I run into in the installation process is that
>> the OS won't run the Bonjour service due to permissions. When I try
>> to run AG3 the first thing I get is that it can't find dnssd.dll.
>> When the venue client comes up and try to enter a venue, Pythonw.exe
>> fails. I'll be looking further into the logs.
>> Jimmy
>> -- Jimmy Miklavcic
>> Multimedia Specialist
>> Jimmy.Miklavcic at utah.edu
>> UNIVERSITY OF UTAH
>> CTR FOR HIGH PERFORM COMPUTING
>> 155 SOUTH 1452 EAST RM 405
>> SALT LAKE CITY, UT 84112-0190
>> Office: 801.585.9335
>> Fax: 801.585.5366
>> http://www.anotherlanguage.org
>> *From:* owner-ag-tech at mcs.anl.gov [mailto:owner-ag-tech at mcs.anl.gov]
>> *On Behalf Of *Nguyen, Doc Lap
>> *Sent:* Thursday, February 15, 2007 12:28 PM
>> *To:* ag-tech
>> *Subject:* RE: [AG-TECH] AG 3.0.2 & Windows Vista.
>> I tried it last week on Windows Vista Enterprise and it initially
>> started, but then quit with an error dialog…probably Python
>> problems.
>> Doc Nguyen
>> *On Behalf Of *Jimmy Miklavcic
>> *Sent:* Thursday, February 15, 2007 12:35 PM
>> *To:* ag-tech
>> *Subject:* [AG-TECH] AG 3.0.2 & Windows Vista.
>> Has anyone been successful in running AG 3.0.2 on Windows Vista?
>> Jimmy
>> -- Jimmy Miklavcic
>> Jimmy.Miklavcic at utah.edu <mailto:Jimmy.Miklavcic at utah.edu>
>> UNIVERSITY OF UTAH
>> Fax: 801.585.5366
>> http://www.anotherlanguage.org <http://www.anotherlanguage.org/>
